Author Topic: I AM SO PISSED OFF AT MY CAR RIGHT NOW!!, @@@@  (Read 4876 times)
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
Re: I AM SO PISSED OFF AT MY CAR RIGHT NOW!!, @@@@
« Reply #20 on: 02 September 2012, 10:25 »
Have you checked if theres fuel getting through just thinking if its your fuel pump or the relay to the fuel pump?I cant remember on my old mk3 but sure you can hear the fuel pump prime up might be wrong just my guess  :grin:
Golf Gti
Offline GOLF-MK3-GTI
« Reply #21 on: 02 September 2012, 18:50 »
Fuel pump is okay, My brothers been driving it since morning, and so far is not troubled him, so fingers crossed, touch wood, but I mean it's intermittent problem, it will only happen once in a blue moon this car has me puzzled,
one thing I want to mention is, it has only started doing this, when I left the car in gear, and I started it by accident, after that this problem has started, could it have knocked the timing out?
Offline Screech16v
  • MK3 20vt AGU
« Reply #22 on: 02 September 2012, 19:52 »
This could not have knocked the timing out  :grin:
« Reply #23 on: 02 September 2012, 22:29 »
Lol ok, atleast I know it cnt be the timing,
Anyway, the cars been on road for the full day and it has been switched on and off quite alot, been on local roads, dual carriageway, and it has not missed a beat, fingers crossed, it stays that way
Offline sharki786
  • GOT BOOST??
« Reply #24 on: 03 September 2012, 13:32 »
sorry took a few days to reply.
if you was closer i couldav swaped my coil pack over with yours but as the cars driving its not the coil pack. the ignition amp has that 3pin connector that connects to the coil (i think) just trace it back and hopefully you should find it. you have changed the relays? check them to see if they get realy hot or are stone cold after the car has been started (if so then you have a duff rellay)
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline twotwofour
« Reply #25 on: 03 September 2012, 14:00 »
I might be wrong but I believe the ignition amplifier is mounted underneath the coil. Remove the coil and you'll see it behind it
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline kaine2010
« Reply #26 on: 03 September 2012, 14:11 »
Right people this is the probelm, I am so confused on what is wrong with it, and i am loosing my patience with this car, Please help..
Yesterday i spent most of the day cleaning all the earth wires on my car, i also cleaned the one's under the battery tray,i replaced the earth wire from the coil to the engine with a new one.
i then got a new coil from GSF, its a good quality one as it has VW & Audi badge stamped on it, anyway i also replaced the roter arm and distrubutor cap as the old one's looked tired.
I took my car from a spin and i've been driving last night, Cleaning the earths have made a lot of difference as my lights have become brighter and i can see where i'm going on a night, lol.
yesterday i turned the engine off about 8 times and started it again and it was perfect.
today morning i started it and it started, been driving it all morning without any trouble.
Right this is the problem,
I parked up in my drive, was going to go out half an hour later, tried cranking it, but wouldnt start, i unplugged the ECU Temp sensor, still no joy, i unplugged maf, still no joy,
I then had my doubts on the coil as i took of the lead that comes from coil into distrubutor and it didn't spark, so i thought its the coil, anyway i had a spare coil in boot that works, so i tried that, but again it did not spark.
I then left the car for half an hour, came back and it started up first time
so now i am thinking if theres no power going into the coil at all, then how will it spark.
I have my doubts on the ECU Relay, No: 30 or could it be the ignition switch?
have any of you had problem like this? Please help.
sounds like it could be the crankshaft sensor i had the same problems last week ended up costing me a fortune and having a lot of unnecessary work done can you get a reading from it ?? if so it will most probs say camshaft sensor which means crank btw :) i replaced mine and its started up fine ever since
« Reply #27 on: 03 September 2012, 15:14 »
well just been out in it again and its perfect, no trouble at all so far,
I have not changed the relays yet, but will do at some point this week, if its not the relays then i will have ago replacing the crankshaft sensor & knock sensor, as they are the only things that need doing.
My brother got a new maf sensor from VW, New distributor, when he got the timing belt changed as well as a new water pump, so i know they all working.
Ive changed the ECU Temp sensor, cleaned the earths up, new coil, rotar arm, new distributor cap.
so as above only got a few niggly bits to replace and it all should be fine...
