Author Topic: I AM SO PISSED OFF AT MY CAR RIGHT NOW!!, @@@@  (Read 4877 times)
Offline GOLF-MK3-GTI
Re: I AM SO PISSED OFF AT MY CAR RIGHT NOW!!, @@@@
« Reply #11 on: 01 September 2012, 22:18 »
ignition amplifier??
what's one of them, sharki786?
lol, I've found out what it is...
« Reply #12 on: 01 September 2012, 22:48 »
http://www.ebay.co.uk/itm/VW-GOLF-MK1-MK2-MK3-MK4-1-0-1-3-1-6-1-8-2-0-IGNITION-AMPLIFIER-MODULE-1983-ON-/300713235851?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4603e7d58b
where are you?
sharki786, what does this amplifier thing supposes to do, I have found it, but I've never seen this or read about it, also where's is supposed to go?
Thanks man
Offline Phil Miller
« Reply #13 on: 01 September 2012, 22:53 »
when the car wont start get someone to crank the engine over and give the amp a tap, it should start up, or another trick is to disconnect the ign amp plug and reconnect it, both have proved the amp is faulty for me in the past, ive got a good s/h amp and relays if you need them mate?
« Reply #14 on: 01 September 2012, 23:02 »
where is this amp located, and thanks fr the above info, appreciate it
if that is the problem, I will give you a shout
« Reply #15 on: 01 September 2012, 23:04 »
Sharki786, I'm based in the Yorkshire area, near Leeds/Wakefield
Offline Phil Miller
« Reply #16 on: 01 September 2012, 23:07 »
its part of the coil, the plug is on the underside of it, iirc its a black plug with 3 or 4 wires going to it, very common to fail, aftermarket ones are crap you need to fit a genuine one
« Reply #17 on: 01 September 2012, 23:38 »
[/quote]
when this fault occurrd on your car, what were the symptoms it was showing?
« Last Edit: 01 September 2012, 23:41 by GOLF-MK3-GTI »
Offline Phil Miller
« Reply #18 on: 01 September 2012, 23:45 »
[/quote]
I've had this many times at work, the symptoms normally are cut out, won't start, no spark, sometimes you don't have fuel flow aswell, now I've also had it before where I've pulled a car in for a service, turned the engine off gone to restart it and it won't go, when I worked for a breakdown company before the Vw Audi Indy, we use to carry them in the vans as they are that common a fault
« Reply #19 on: 02 September 2012, 09:35 »
I am confused on where this part is tbh, because your saying it's part of the coil and it has 3 or 4 wires going to it, but sharki786 at the top he's posted a link via eBay, and that add says it normally has 6 to 7 pin connector?,
