Author Topic: Adaptors to fit modern battery in MkIII  (Read 1753 times)
Offline TwoGapper
« on: 01 September 2012, 09:44 »
I've got an old Varta in my MkIII but the new batteries have a different "hold down" height..
The stock battery has a edge lip of 19mm tall, so the new batteries with a 10mm edge are loose under the slot at the back and the clamp doesn't fit right.
I've heard there are adaptors for this.. but where do you get them.. and are they brand specific (ie I want to fit a Bosch S4 063 do I need a Bosch one) ??
Could just wedge something in there I suppose.. but what??? I'd rather do it properly though tbh
Didn't think I'd have this much trouble just replacing the battery LOL!  :smiley:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Adaptors to fit modern battery in MkIII
« Reply #1 on: 01 September 2012, 09:54 »
I've had this issue on other cars before, quite often it can ce sorted by flipping the clamping plate over or shimming it out to suit.
VW BUSH
« Reply #2 on: 01 September 2012, 14:20 »
This is what I did on my new battery :wink:
Offline twotwofour
« Reply #3 on: 01 September 2012, 20:02 »
Mine has an adapter. It a plastic shim like you mentioned. I'd be surprised if the place that would sell you te battery couldn't provide one
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline TwoGapper
« Reply #4 on: 02 September 2012, 16:41 »
Was able to get just one adaptor from a car parts shops after trying loads of places... fitted that on the side which goes under an edge, then on the other side flipped the clamp round (front to back not upside down) and once tightened that seems quite a snug fit. :smiley: Thanks for the idea guys
For future reference, the VAG part number is 000-915-413. Very hard to find IME but some on ebay atm
http://www.ebay.co.uk/itm/270935283204
« Last Edit: 02 September 2012, 16:43 by TwoGapper »
Offline Bandit127
« Reply #5 on: 07 September 2012, 18:52 »
Rotate the plate round 180°. Not the best of engineered solutions but it works and will get you through the MOT.
