Author Topic: VVT an agu engine???  (Read 2641 times)
Offline Phil Miller
« on: 31 August 2012, 23:06 »
is it poss to fit the VVT unit from say an ARY engine to an AGU engine, looks like the VVT unit will just unbolt, can this be done, has anyone done it, whats it like to do?
Offline Chris.
Re: VVT an agu engine???
« Reply #1 on: 01 September 2012, 20:31 »
Yeah, The parts physically fit as you just unbolt tensioner, and cams and drop whole unit in....however, your ECU wont run it.
Click For Build Thread
Offline Phil Miller
« Reply #2 on: 01 September 2012, 22:25 »
Yes it will as the cars an A3 that had an ARY 180 vvt, all ive done is replace the furbed engine with an AGU (was mega cheap) runs spot on, pulls well and TBH if it wasnt for the ECM light being on i wouldnt worry about fitting it, but as i have the VVT unit seems silly not to fit it as it will bolt in
Offline Chris.
« Reply #3 on: 02 September 2012, 12:05 »
Ahhh, thought you were running AGU managament.
Offline Phil Miller
« Reply #4 on: 02 September 2012, 16:12 »
No mate still using the ARY loom and ecu mate
