Author Topic: rs8 alloys spacer help  (Read 811 times)
Offline puzzled
« on: 31 August 2012, 16:53 »
does any body know what mm spacers to use with rs8 alloys
http://uk-mkivs.net/forums/t/271052.aspx
to make them look flush with the arch ?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: rs8 alloys spacer help
« Reply #1 on: 01 September 2012, 12:26 »
all depends on the offset of the wheel and width.
If they are ET35 8J you could probably have 20mm rear 10mm front. Although to play it safe I went for 5mm front 15mm rear keeping the tyres away from the arch by about 2-3mm
Offline puzzled
« Reply #2 on: 01 September 2012, 14:23 »
ok thanks, i cant remember the offset, fininhed spraying them last week,
just need tyres and to fit but i remembered the front wheel just sits on the suspension leg (coilovers)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 01 September 2012, 15:52 »
you need at least 5mm spacers on the front whatever happens then, same with most coilovers
