Author Topic: vinal wrap help  (Read 1957 times)
Offline luke300586
vinal wrap help
« on: 30 August 2012, 21:32 »
i tried to vinal wrap my interior trim in brushed alloy i got some of my local signage company but it wont seem to stick to the trim, any ideas?
Offline 1stevester1
Re: vinal wrap help
« Reply #1 on: 31 August 2012, 21:06 »
Have you cleaned the trim with pre wipe or similar to take all the crud off you carnt see a bit like panel wipe
Offline Callum82
Re: vinal wrap help
« Reply #2 on: 03 September 2012, 21:50 »
Do you need a heat gun for vinyl?
Offline AntsRants
Re: vinal wrap help
« Reply #3 on: 15 October 2012, 09:57 »
When I did mine (since changed it) I used a hair dryer as you don't need it super hot, just enough to make it pliable.  As said, de-grease the trim first, I just sanded mine down as the wood trim will NEVER be on show again.   Tip is not to heat it too much as the vinyl will bubble with the heat.  Take your time and you'll do a good job, just make sure you have enough for each item and do a little bit more as you can always trim it back, and looks pants if you start adding patches to it.  Hope this helps, and good luck!
