Author Topic: cossie yellows in agu ??  (Read 2063 times)
Offline madhead1987
« on: 30 August 2012, 21:09 »
hi ,all i was on the serch for some yellow calibra injectors and eneded up with cossie yellows , my question is will they work better or worse than the calibra ones ?i did some reserch on then there flow rate is 311cc per min any help would appreciated
reece
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: cossie yellows in agu ??
« Reply #1 on: 30 August 2012, 21:59 »
I think they are different impedance mate so won't be any good
Give me a part number and I'll look it up after work tomorrow
Offline Chris.
« Reply #2 on: 31 August 2012, 00:28 »
Bosch part number?
Same chubby fitment as AGU ones?
Click For Build Thread
Offline madhead1987
« Reply #3 on: 31 August 2012, 13:25 »
There not Bosch there weber did some research last night this Is what I found
Weber Iw-025/02 injectors flowing around 300cc @3 bar 2.4 ohm
Believe to be same as Bosch light green 280 150 355 don't quoted on that tho
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 31 August 2012, 13:34 »
Cossie yellows were only used in the RWD Cosworths. They changed to blues in the 4x4. Should be the same fitment but not sure on impedance yet, bear with me
« Last Edit: 31 August 2012, 13:35 by Wazzzer »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 31 August 2012, 13:40 »
Cossie injectors are very low impedance, 2.4ohms. Calibra yellows are 14.5ohms
Offline madhead1987
« Reply #6 on: 31 August 2012, 14:53 »
Does that mean no good ? Or ok ?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 31 August 2012, 14:57 »
no good mate. The impedance needs to be close or exactly the same
Low impedance injectors are peak and hold type, they are designed to work with an injector signal that has an initial peak voltage to get the injector open as fast as possible (this is good) and then a maintenance voltage to hold the injector open for as long as desired (about half as much as the open signal). This system allows for a high initial peak current that would other wise damage the injector if used continuously.
High impedance injectors are saturation type injectors, they are designed to use a simple square wave signal to open and close the injector.
Offline madhead1987
« Reply #8 on: 31 August 2012, 15:05 »
Is there a way I could make them work ?
Offline Chris.
« Reply #9 on: 01 September 2012, 20:37 »
doubt it
calibra yellows can be had for £30-40
