Author Topic: Help what coolant  (Read 9141 times)
Offline Davstylee
Help what coolant
« on: 30 August 2012, 19:13 »
Im guessing a very easy one but I'm a little confused. The hand book says use G12 and it is purple in colour, but I have a red/pink colour colour in mine. What one should I be using and where's best to buy it? Only need a little as its just a quick top up.
Thanks and sorry for being a complete fool.
Mrk V, GTI, 3dr, DSG, heated seats, winter pack, cruise control, rear parking sensors and now thanks to GizzyWizzy and SteveP in the MK6 section a RCD 510. Awesome!
Offline bacillus
Re: Help what coolant
« Reply #1 on: 30 August 2012, 19:37 »
You need VW G12+ antifreeze.
If you just need a little for top up then it's ok to just use water as a small dilution will not significantly affect the freezing point of the mixture.
Without traction power is nothing!
Offline Davstylee
« Reply #2 on: 30 August 2012, 21:02 »
Ok awesome, is that pink or purple in colour and would somewhere like Halfords sell it? Don't you need some sort of special distilled water?
Offline bacillus
« Reply #3 on: 30 August 2012, 22:49 »
Get the coolant from VW, it's pink in colour and sold in 1.5l bottles.
You can use distilled water but I've always used tap water in the past.
Offline Davstylee
« Reply #4 on: 01 September 2012, 11:48 »
Quick question just been to the stealers and they say G12 pink/red coolant is no more it's G13 purple only now. They also said G12 will mix with G13 no problems. So question is do you think this is true? I have the pink/red coolant in there at the moment but need to top it up. Do you think it will be safe to top up with the G13 purple?
Offline Gene Hunt.
« Reply #5 on: 26 September 2012, 08:18 »
......''yes'' mate it will be fine it will still be the O.A.T. spec.
Candy White ED35.
Offline MS1COYS
  • Alfie 'H' 10-09-11
« Reply #6 on: 26 September 2012, 11:59 »
According to VW in Westbury, Wilts, you can use a universal antifreeze. In fact they suggested it as it is cheaper than the VW branded stuff    :undecided:
I've used this since I owned I've the car and had no problems...
http://www.europaparts.com/pentofrost-plus-plus-g12-extended-life-engine-coolant-5-liter.html
Sits at a healthy 80-90c. Warm up time usually around 1.5-2 miles. Never looses coolant or needs topping up. No corrosion or brittle pipes.
 :smiley:
« Last Edit: 26 September 2012, 13:59 by MS1COYS »
292bhp / 287lbft
Offline vii-cks
« Reply #7 on: 26 September 2012, 13:13 »
G12 part no G012A8GM1 isnt available anymore its the new generation G13 but can mix the fluids even with previous like G12++ and G11. Part number you want is G013A8JM1.
Offline MS1COYS
292bhp / 287lbft
