Author Topic: headliner wet at rear  (Read 1054 times)
Offline player.777
« on: 30 August 2012, 19:12 »
hi guys, from searching I understand this is a problem to do with the rear wash connectors or pipe- I have found this on the common faults thread:
My rear seats and boot lining are wet
First of all, check the headlining. If that's wet as well, it's probably caused by the rear washer hose connection - click here for a fix
The 'click here' doesnt work- does anyone know what link this is supposed to go to? Or how to fix the problem?  Thanks a lot.
Offline Mr_Orange
Re: headliner wet at rear
« Reply #1 on: 30 August 2012, 19:32 »
Where the n/s rubber flexi goes into the boot at the hinge corner, the hose can perish from flexing back and forth or pop off the 90deg connector hidden up in there.  You may need to drop the headlining to check this out.
Here's a link with some relevant images:
http://uk-mkivs.net/forums/p/324402/2184894.aspx
With the headlinig dropped down also make sure the leak aint coming from your aerial base ;)
Build thread clicky
