Author Topic: To all you 1.8t conversion owners!  (Read 7961 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: To all you 1.8t conversion owners!
« Reply #20 on: 30 August 2012, 22:18 »
Have you had it hooked up to Vag Com ??  is so what is it saying ?
if it was a immobiliser issue, the car would run for 1 second then shut down so its not that
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Gash
« Reply #21 on: 30 August 2012, 22:21 »
yep plugged vagcom into it and only thing showing is throttle position sensor.
Offline 67buggers
« Reply #22 on: 30 August 2012, 22:32 »
Mate get on edition and check out that vento splitt thread.....the being delivered this week and the is some extras in the I think......nothing to do with your engine sorry!
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Offline F17BAD
« Reply #23 on: 30 August 2012, 22:53 »
have you tried to align the TB via Vag com ?
mine does this automatic once if the battery has been disconected but im not sure on the non S3 engines.. their is a function on vag com to do it
Offline CJA321
« Reply #24 on: 30 August 2012, 22:59 »
My AGU does it automaticly also.
Offline Dan_GTi8v
« Reply #25 on: 31 August 2012, 06:24 »
if you dont do it on vagcom they all do over time apparently, the ecu kinda adjusts itself so the more you drive it the better it gets till its running properly
thats what I read anyway it may well be a load of bollocks  :laugh:
Offline AudiA8Quattro
« Reply #26 on: 31 August 2012, 16:30 »
I thought the throttle body had to be calibrated on all 1.8T engines if replaced?
Offline Gash
« Reply #27 on: 31 August 2012, 16:33 »
how can the throttle body be calibrated if its wired?  still no luck my mate thinks iv got a bad chip, but spoke to the company that sent the ecu and they said it was tested fine before being sent out
« Reply #28 on: 01 September 2012, 10:19 »
Correction, i think only fly by wire engines need throttle body calibration.
Can anyone confirm?
Offline F17BAD
« Reply #29 on: 01 September 2012, 19:08 »
Can anyone confirm?
just need aligning mate.. vag com or automatically does it via the ECU
