Author Topic: Upper strut installation  (Read 1209 times)
Offline Rob Zombie
« on: 29 August 2012, 19:44 »
Evening lads,
I've just purchased myself a upper strut brace for my mk2 golf gti.
I'm just wondering is there a best way of fitting these or anything I should be aware of?
I've googled quite a bit and can't find any instructions on how to fit one to a mk2
Robb
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
Offline antogoof
  • bbm mk2 g60
Re: Upper strut installation
« Reply #1 on: 29 August 2012, 20:18 »
youve got to drill the strut tops inside the engine bay, best advise i can give is measure twice drill once. if you are not sure on how to do it get it to a garage, it might look straight forward but it can be a b!tch if you dont measure it right. :smiley:
mk2 bright blue met bits wanted in north west.
Offline Rob Zombie
« Reply #2 on: 29 August 2012, 20:41 »
Cheers fella,
Should come through in the post tomorrow. So hopefully get in on this weekend...
I imagine theres not much point in a rear strut or lower front for the mk2 ?
Robb
BHP: 231
TRQ: 251.7 lb-ft
