Author Topic: mk4 centre sun visor fitting??  (Read 1806 times)
Offline vwgolf182
« on: 29 August 2012, 17:40 »
ive searched an cant find the fitting guide anywhere jus wondered if someone could send me the link?
cheers
Offline AcidicDavey
  • Not a VAG Owner.
Re: mk4 centre sun visor fitting??
« Reply #1 on: 29 August 2012, 20:32 »
Surely you'd just need to puncture a hole through the lining and get a small nut and bolt, then job done!
95 Volvo 480 2.0 Celebration
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Offline AcidicDavey
  • Not a VAG Owner.
« Reply #3 on: 29 August 2012, 23:55 »
So you could just tuck it under the headlining?
That's my kind of install!
Offline Edwh0re
« Reply #4 on: 01 September 2012, 06:32 »
The ones that tuck under the headlining are not Mk4 ones...
« Reply #5 on: 01 September 2012, 07:53 »
The mk2 ones clip over the leading edge of the roof lining.
Offline mark-mk3gti
« Reply #6 on: 01 September 2012, 19:38 »
after fitting mine, i think it would be better to flatten the big centre bulge and leave the smaller outer clips in tact, then puncture the head lining in the right place, small nut and bolt, and jo done..
hint take out the light and you can just reach the top of the bolt and fit the nut, be aswell to use a decent size washer also...
Offline AcidicDavey
  • Not a VAG Owner.
« Reply #7 on: 02 September 2012, 00:57 »
I test fitted the TT one I got and folded it under the the headlining just to see. Will fit properly when I retrim the headlining!
