Author Topic: 1.4 clutch  (Read 1381 times)
Offline Willo
1.4 clutch
« on: 29 August 2012, 10:46 »
How hard is it to replace the clutch on my mk3 1.4 its a 94 model
Thanks in advance
Offline spudboy6
  • Just like a golf ......
Re: 1.4 clutch
« Reply #1 on: 29 August 2012, 17:25 »
All depends in your confidence and knowledge , there an easy gearbox hardest bit is the clutch cable no playing ball when trying to remove / refit ,
You split the drive shafts , remove battery tray and gear linkages pop off , remove starter motor and undo bell housing bolts and remove the clutch cable.  Bobs your uncle
« Last Edit: 29 August 2012, 23:02 by spudboy6 »
