Author Topic: 16v , VR6 or 16v anni?  (Read 7480 times)
Offline mrsaunders
Re: 16v , VR6 or 16v anni?
« Reply #20 on: 29 August 2012, 10:02 »
Well once I sell my 1.8t, I should have around £1500/1600 to spend.
Need to start looking around. Still torn between the anni and vr6 now
If you are planning on keeping it standard (maybe just a cheeky drop on the suspension) then the Annie could be a good investment, if however, you are wanting to mod the car I wouldn't bother with an Annie, I think they should be left as original as possible.
I am obviously biased since I own a VR, but you could pick up quite a tasty one for that sort of money, I can't help thinking you would be slightly disappointed with the Valver performance after your 1.8T
i doubt you'd be dissappointed, both standard then a mk3 16v is just a fraction quicker then a 1.8t so i dont see how you could be?
Offline Foreveryoungaus16v
« Reply #21 on: 29 August 2012, 12:00 »
I ane owned both vr6 and 16v. The 16v is way better esp if u get head port etc done. The vr6 is not that much quicker period.
163 BHP (TSR POWER RUN)
Offline AudiA8Quattro
« Reply #22 on: 29 August 2012, 12:48 »
Standard versus standard, the vr is still considerably quicker than the 16v.
Change the upper inlet manifold and throttle body for a 2.9, remap it, and you'll have the same power as the corrado...
The 16v is much more expensive to tune, period..
Offline Ess_Three
« Reply #23 on: 29 August 2012, 12:53 »
True.
But the 16v had lower gearing to make better use of the lower torque but higher revs...and will ALWAYS understeer less than a VR6.
You pays your money and makes your choice!
..but gaining motorcycles.
« Reply #24 on: 29 August 2012, 12:54 »
Standard vs standaird the vr is not a lot quicker period. I hav owned 3 vrs all mint standard. Not a lot of diff except on motorway
« Reply #25 on: 29 August 2012, 13:01 »
That's like saying there isn't alot of difference between the 8 and 16v  :smug:
« Reply #26 on: 29 August 2012, 13:03 »
True.
True the 16v will always handle better when really pushed..
But the VR6 IS quicker than the 16v, there is no doubt about that...
« Reply #27 on: 29 August 2012, 13:07 »
This conversation can go on all day :grigbn:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #28 on: 29 August 2012, 13:09 »
Keep fueling, keep fueling... :evil:
« Reply #29 on: 29 August 2012, 13:11 »
Yes it could.
I like both engines  :smiley:
