Author Topic: Water pipe pressure mk3 vr6  (Read 1192 times)
Offline chezney55
« on: 28 August 2012, 07:47 »
Alright. Well basically was wondering what kind off pressure is ment to be in the water pipes when up to runnining temp, because you can squeeze mine right together? Any help would be great!
Offline seanyd
Re: Water pipe pressure mk3 vr6
« Reply #1 on: 28 August 2012, 07:54 »
Normally the water runs through it but not at a lot of pressure u should feel a little pressure wen squeezing together but not loads mate
Offline seanyd
« Reply #2 on: 28 August 2012, 07:59 »
Also aslong as its not overheating you should be ok
Offline chezney55
« Reply #3 on: 28 August 2012, 08:10 »
It's not over heating it's running at normal Temp I thort maybe an air lock! Will keep an eye out. Cheers mate
Offline mrsaunders
« Reply #4 on: 28 August 2012, 09:07 »
sounds pretty normal to me
