Author Topic: what clocks to use on a g60 conversion?  (Read 5237 times)
Offline antogoof
  • bbm mk2 g60
Re: what clocks to use on a g60 conversion?
« Reply #10 on: 28 August 2012, 21:34 »
so they are pretty rare as well then? how often do you get them in roughly?
mk2 bright blue met bits wanted in north west.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #11 on: 28 August 2012, 21:37 »
Depends on what cars I get in or what I can drop on...
These clocks used to fetch £80.00 10 years ago, so prices have come down as such... Saw some listed on a VR6 thread from way back when...
For More Info Click To See;
Offline antogoof
  • bbm mk2 g60
« Reply #12 on: 28 August 2012, 23:17 »
hmmm, ill have to keep an ear t`ground eh? might look at an astra gte conversion, used to love them clocks. :smiley:
Offline Simeon
« Reply #13 on: 29 August 2012, 15:42 »
I think you need CE2 (Single pin) 16V 160mph & 7.2 Rev limit clocks..
That's why they fetch over £100 a set...
No, for a G60 you want 8v Gti 6k red line clocks.
And 16v clocks sell for circa 20-30 quid.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #14 on: 29 August 2012, 16:02 »
Thanks for the useful Info....
Lets not start all this again....
CE2 16V clock are current selling for around £100.00 a set.... Go Check Ebay!!
AND I'm Not Selling Any.... Despite what is reported on another Forum
« Last Edit: 29 August 2012, 16:04 by X4MGS »
Offline antogoof
  • bbm mk2 g60
« Reply #15 on: 29 August 2012, 18:17 »
i believe ive got a set of these, but they are on a speedo drive, where as the rado box i have uses cable change and a digi drive? anyone know where to get the cabe to mate the two?
Offline Dolly
« Reply #16 on: 29 August 2012, 18:27 »
cant help too much, but i did one with mk 8v 90 spec clocks and a mk2 1.3 speedo cable. the box was cable change O2A is it.
Offline antogoof
  • bbm mk2 g60
« Reply #17 on: 29 August 2012, 20:12 »
anyone got a pic of the drive on the box? im a bit confused as to where it goes! :smiley:
Offline Simeon
« Reply #18 on: 30 August 2012, 13:33 »
I'm not starting anything mate. They may be advertised on ebay for £100, but luckily if one removes the 'ebay blinkers' one can buy them for a lot less.
To the OP, as above you can use a cable Speedo with an O2A 'box, have a little search and I'm sure there'll be a thread detailing how.
Offline Dolly
« Reply #19 on: 30 August 2012, 20:37 »
http://forums.vwvortex.com/showthread.php?2510161-1.8T-G60-gearbox-mk2-cluster...
check this out pal, the picture halfway down shows where it goes, like i say i used a mk2 1.3 drive and it worked fine in my 8v clocks
