Author Topic: Silicone pcv kit  (Read 1777 times)
Offline cooki
  • 1.8T AUM
Silicone pcv kit
« on: 27 August 2012, 15:05 »
Any body no if this kit will fit my 1.8T AUM it states on the add it's for engine AWP so no idea if any of it will fit???
http://www.ebay.co.uk/itm/VW-Golf-1-8T-Induction-PCV-Boost-Turbo-Hose-Kit-/220870210466?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item336ce3f3a2&_uhb=1#ht_1402wt_1008
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline cooki
  • 1.8T AUM
Re: Silicone pcv kit
« Reply #1 on: 27 August 2012, 18:25 »
Also do u think it contains pipe no2 from this picture (says upper and lower pcv pipes included) as that's the main 1 I need as mine is split.
I have temp repaired my pipe for now because this kit will take weeks to arrive.
Offline Dave_IOW
« Reply #2 on: 27 August 2012, 23:19 »
Not tempted to rip the PCV system out and fit a catch can?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline cooki
  • 1.8T AUM
« Reply #3 on: 28 August 2012, 00:42 »
Very tempted mate yes but just can't quite work out exactly what I need.cant get an exact fit can so need reducers and allsorts for the piping don't u. Proper mine field lol.
Offline GTi_James
« Reply #4 on: 28 August 2012, 10:04 »
this is what i got, went for the square one though starting to think i should of got the round one
http://www.ebay.co.uk/itm/271014842282?var=570100864782&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
http://www.ebay.co.uk/itm/350572013967?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
http://www.ebay.co.uk/itm/320913278477?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
^^^^Cable Tie Mech^^^^
http://www.ebay.co.uk/itm/130646945675?var=430052054984&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
http://www.ebay.co.uk/itm/330697625414?var=540057380893&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
http://www.ebay.co.uk/itm/290742298928?var=590074415522&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
still waiting for this part after a friggin month
but thats all i got though would like to know if i missed anything out
thinking of getting these as well to stop pipes from crinkling
http://www.ebay.co.uk/itm/330697625414?var=540057380924&ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
hope this helps
P.S. this is from another post, alot better and alot cheaper in the long run, get rid of your PCV syste, N249 and SAI - BANG - no problems with your vacuum system, no more worries of under boosting
Offline Dave_IOW
« Reply #5 on: 28 August 2012, 10:22 »
Depends on budget, if you want a no hassle approach, Saiko catch can, 19mm ID oil resistant hose (2meters), 19mm T piece and 90degree bend and that's it.
Offline jamie1989
« Reply #6 on: 28 August 2012, 10:28 »
Agreed, although ebay special and common sence you could do it for -£50.
Those Saiko catch can's look so much better tho  :cool:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline GTi_James
« Reply #7 on: 28 August 2012, 10:29 »
+1 TBH
Offline JimBR
« Reply #8 on: 28 August 2012, 13:05 »
The awesome can is £80 and has 19mm fittings and you can get the hose and t pieces ect for about £20. I'ts about £50 more but the can is baffled and looks much better  :smiley:
