Author Topic: OUTER CV BOOT 16V F REG  (Read 2113 times)
Offline moonraker
« on: 05 October 2003, 17:14 »
Have to change the cv boot for the dreaded mot - still could be worse.  Have you got any tips on doing the job or any advise please - I'm assuming that once I've removed the drive shaft from the car, one of the cv joints will be removable and i'll be able to replace the boots.
Has anyone had any success stretching the outer boot over the joint in situe useing a metal cone made of steel rod as I can make one a work
Cheers  Steve
golfvr6
Re:OUTER CV BOOT 16V F REG
« Reply #1 on: 05 October 2003, 18:28 »
Remove the driveshaft from the car , the outer joint will separate from the shaft by banging it with a rubber mallet.
Offline modulater
« Reply #2 on: 05 October 2003, 22:30 »
I think its easier to do the job off the car. take the shaft off and hold it in a vice and as VR6 says hit the joint with a rubber mallet. you have to hit it quite hard to get it to ping past the spring clip on the shaft.
Wash the old one out with petrol and let it dry then fully lube it up with the grease you get in the cv kit.
Offline richandhazel
« Reply #3 on: 07 October 2003, 13:33 »
re your email, here is the link that you were after:-
http://homepage.ntlworld.com/richandhazel1/gti/profix/running/main.htm#cv
