Author Topic: best thing to use to stick my vw badge  (Read 1549 times)
Offline Mk2_tel
« on: 27 August 2012, 10:57 »
back on my boot lid?
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Re: best thing to use to stick my vw badge
« Reply #1 on: 27 August 2012, 16:42 »
Sikaflex? Strong double sided numberplate tape?
Offline cooki
  • 1.8T AUM
« Reply #2 on: 27 August 2012, 19:12 »
I tried strong double sided number plate tape and just cought the badge in car park hanging off so I sticker flexed it.
Needless to say its not going anywer now  :evil:
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline Steve_PD
« Reply #3 on: 27 August 2012, 21:03 »
Mine held on using thin numberplate tape. No problems in 4 years.
Offline Toby
  • Car - less
« Reply #4 on: 27 August 2012, 21:16 »
This  :wink:
Currently down under
« Reply #5 on: 27 August 2012, 21:38 »
You can get trim tape in Halfords which will do the job :afro:
Offline dom
  • Back in a Mk4
« Reply #6 on: 27 August 2012, 23:07 »
I've also struggled to stick mine back on, I've used all kinds of trim tape and none of them work particularly well :undecided:
Offline Mk2_tel
« Reply #7 on: 30 August 2012, 20:18 »
cheers all i thought i was asking a silly question at first haha
Offline Scott D
« Reply #8 on: 30 August 2012, 20:55 »
As suggested trim tape from Halfords - used this on the rear VW badge for 2+ years now still holding strong.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
