Golf mk4
Wazzzer
linear o2 sensor?
Topic: linear o2 sensor? (Read 1104 times)
birch
linear o2 sensor?
27 August 2012, 10:09 »
i have two fault codes 17586 and 17598 which seem to point to he 'linear o2 sensor' which one of the two lambdas is the 'linear o2 sensor' any help please? engine management light is on! its a 1.6 16v engine code AZD, thanks.
Dalo Harkin
Re: linear o2 sensor?
27 August 2012, 14:34 »
you'd be better off replacin one of them and see if the code goes if it does you got the right one, I had to do this on my 1.8T because VAGCOM didnt say which one was shot just that one of them was
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
Golf mk4
Wazzzer
linear o2 sensor?
