Author Topic: Check your oil!  (Read 2485 times)
Offline Ibanezvaio
Check your oil!
« on: 27 August 2012, 08:38 »
Morning everyone. So as the title says, check your oil level (and top up as appropriate)!
Checked mine the other day (usual monthly check) and realised it was on the min level. Bought a litre top up of choice and filled when the engine was cold. Took it out last night for a good run and the difference was incredible. She'd been running slightly rough, nothing too serious but enough for me to investigate and take it easy.
Moral of the story is, if you think something's not right, check your oil level! It could save your engine for starters but also let you enjoy your smooth running motor
Offline Snoopy
  • Moderator
  • Geoff.
Re: Check your oil!
« Reply #1 on: 27 August 2012, 09:44 »
So you went from max to min in a month  :shocked: I think I would be looking for a leak if that happened to me.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Gene Hunt.
Re: Check your oil!
« Reply #2 on: 27 August 2012, 10:40 »
My ED30 never needs a top up between servicing.
Candy White ED35.
Offline Ginge 35Edition
Re: Check your oil!
« Reply #3 on: 27 August 2012, 10:45 »
Just checked mine and gave her a little drink.
Offline Ibanezvaio
Re: Check your oil!
« Reply #4 on: 27 August 2012, 17:00 »
Nope, was aware that it could have done with topping up but due to other commitments, was put to the back of the queue.
Glad I seemed to have helped someone at least
Offline Snoopy
  • Moderator
  • Geoff.
Re: Check your oil!
« Reply #5 on: 27 August 2012, 17:36 »
Note to all GTI EA888 owners: A few engine failures of TSI2.0 out there that are suspected due to the chain jumping teeth due to the chain tensioner not having enough engine oil/pressure so check your oil level.
« Last Edit: 27 August 2012, 17:39 by Snoopy »
Mk6 GTI  &  Mk1 GTI
Offline Poached
Re: Check your oil!
« Reply #6 on: 30 August 2012, 19:01 »
Have you measured your oil consumption at all snoop?
Many mk5's (Both TFSI and TDI) drink oil and from what I have heard the TSI engine fairs much better in the oil gobbling stakes.
But VW have covered themselves with the a 1L in 600 miles being within tolerance! :shocked:
Offline Snoopy
  • Moderator
  • Geoff.
Re: Check your oil!
« Reply #7 on: 30 August 2012, 19:18 »
Mine until I stopped using it at the end of march this year has not used any to speak of, first year over its 3000 miles it used non. Year 2 over  5300 mile only Feb it used 0.1 ltr. (that could have been start of my oil leak)
I don't use it in winter months but use a SEAT Leon 1.9 TDI which also has not used oil. Our SEAT ibiza 1.4 does use oil though.
Mk6 GTI  &  Mk1 GTI
Offline Edi35
Re: Check your oil!
« Reply #8 on: 30 August 2012, 22:26 »
Yes I have heard about 2.0 TSI engines using oil, however I have not had this issue with ED30, MK6 or ED35 and not needed to top up either between services. I did notice that when I got back from France that the oil level has dropped a little on the ED35 but top up not needed and this had done nearly 9000 miles. Had it serviced at 9500 miles. Now it's done 10000 and still on max.
Different story on the Polo GTI 6R the 1.4 TSI was burning 1 litre in 400 miles  :shocked: Got rid of it as a result.
Current: GTI Edition 35 Candy White 5dr DSG 19" Glendale, RCD510+DAB, Dynaudio, Storage Pack, Parking Sensors
Gone: Edition 35, GTI Mk6, Edition 30, GTI Mk4, GTI Mk3, GTI Mk2 and my favourite the UR quattro
For those that dont know DSG is an electronically controlled dual-clutch multiple-shaft manual gearbox
