Author Topic: VDSlite block measurements (Have I got a leak?)  (Read 6680 times)
Offline Nino
« on: 26 August 2012, 20:37 »
I did post this in my last topic but got no answer so thought Id make the question more prominant.
http://www.golfgtiforum.co.uk/index.php?topic=239141.0
Basically Im having these error codes..
17545/P1137/004407 - Fuel Trim: Bank 1 (Add): System too Rich
17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
So far I have...
    Had new coil packs.
    New Temp sensor.
    New Termo
    New DV
    Full major service inc belt & water pump
    New MAF
    Repaired the faulty secondary air pump (thinking of replacing it)
Someone advised me to do a block measure in VDSlite but it makes NO sence to me, can someone take a look and tell me if this looks right?  :undecided:
Current - MK6 GTi Edition 35
Offline shaft69
Re: VDSlite block measurements (Have I got a leak?)
« Reply #1 on: 27 August 2012, 08:04 »
Looking at your fault codes do point to air leak fuel been added ti compensate, need check all breathers and pipes. vdslite pretty rubbish tell truth can't any logging.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 27 August 2012, 09:06 »
You need to do some logs really
Offline Nino
« Reply #3 on: 27 August 2012, 09:32 »
How do I do logs?  :huh:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 27 August 2012, 11:26 »
see that button at the bottom of the screen that says log...
Offline Nino
« Reply #5 on: 27 August 2012, 11:58 »
lol ok i'll get the info from that when the rain buggers off and post it.  :grin:
Offline dan2252
« Reply #6 on: 27 August 2012, 12:19 »
the first fault is stored in my cars ecu too. i think its due to my exhuast blowing very badly just before the lambda dont supose yours is blowing? acording to computer at work it means the ecu has adjusted the fueling as much as it can, also this vagcom version you have where did you get it from? im trying to find some software i can do logs with, without having to pay £200+ haha :)
MK4 golf 1.8 turbo agu :)
Offline Nino
« Reply #7 on: 27 August 2012, 14:03 »
Don't think its blowing, except for the secondary Air pump.
I have done another scan and taken more pic and got a log (Wazz) hopefully this will make sence to someone.
Seems one of the codes is gone hopefully for good  :cool:
I then did a log for about 3 mins and took her for a small drive while the log was running.
Code: [Select]
Monday,27,August,2012,13:42:03
06A 906 032 HJ,,1.8L R4/5VT         0002,
Marker,Group A:, Not Running,,,,Group B:,'001,,,,Group C:,'002
,,,,,,,Engine Speed,Coolant,Lambda Control,Basic Setting,,Engine Speed,Engine Load,Injection Timing,Mass Air Flow
,TIME,,,,,TIME,(G28),Temperature (G62),Bank 1,Requirements,TIME,(G28),,,(G70)
Marker,STAMP,,,,,STAMP, /min,°C,%,,STAMP, /min,%, ms, g/s
,,,,,,0.00,760,72.0,-18.0,00111110,0.37,760,36.1,2.38,2.89
,,,,,,0.77,760,72.0,-18.8,00111110,1.19,760,35.3,2.38,2.75
,,,,,,1.67,760,72.0,-22.7,00111110,2.07,760,35.3,2.38,2.78
,,,,,,2.48,760,72.0,-23.4,00111110,2.87,760,35.3,2.38,2.75
,,,,,,3.28,720,72.0,-23.4,00111110,3.68,720,36.8,2.38,2.97
,,,,,,4.08,720,72.0,-22.7,00111110,4.48,760,37.6,2.38,2.97
,,,,,,4.88,760,72.0,-20.3,00111110,5.30,760,36.1,2.38,2.92
,,,,,,5.70,760,72.0,-21.9,00111110,6.10,720,36.8,2.38,2.89
,,,,,,6.50,760,72.0,-21.9,00111110,7.01,760,36.1,2.38,2.92
,,,,,,7.41,760,73.0,-21.1,00111110,7.91,760,36.1,2.38,2.81
,,,,,,8.42,760,73.0,-21.1,00111110,8.91,720,36.1,2.38,2.81
,,,,,,9.31,760,73.0,-19.5,00111110,9.71,760,36.1,2.38,2.83
,,,,,,10.11,760,73.0,-19.5,00111110,10.53,760,36.1,2.38,2.89
,,,,,,11.02,760,73.0,-19.5,00111110,11.54,760,36.1,2.38,2.94
,,,,,,12.03,760,73.0,-18.8,00111110,12.43,760,36.8,2.38,2.97
,,,,,,12.94,760,73.0,-21.1,00111110,13.44,760,35.3,2.38,2.78
,,,,,,13.94,760,73.0,-21.9,00111110,14.35,720,35.3,2.38,2.72
,,,,,,14.75,760,73.0,-23.4,00111110,15.15,720,36.1,2.38,2.86
,,,,,,15.55,720,73.0,-23.4,00111110,15.95,760,36.1,2.38,2.81
,,,,,,16.46,720,73.0,-21.9,00111110,16.86,760,36.1,2.38,2.81
,,,,,,17.36,720,73.0,-20.3,00111110,17.86,720,36.8,2.38,2.97
,,,,,,18.27,760,73.0,-18.8,00111110,18.67,760,36.1,2.38,2.89
,,,,,,19.06,760,73.0,-18.0,00111110,19.47,760,35.3,2.38,2.81
,,,,,,19.87,720,73.0,-20.3,00111110,20.29,760,35.3,2.38,2.83
,,,,,,20.69,760,73.0,-21.1,00111110,21.09,720,36.1,2.38,2.83
,,,,,,21.49,720,73.0,-20.3,00111110,21.87,760,36.1,2.38,2.94
,,,,,,22.29,720,74.0,-18.8,00111110,22.80,760,36.1,2.38,2.94
,,,,,,23.20,760,74.0,-18.0,00111110,23.60,760,36.1,2.38,2.89
,,,,,,24.00,760,74.0,-18.8,00111110,24.40,760,35.3,2.38,2.83
,,,,,,24.80,760,74.0,-18.8,00111110,25.21,760,35.3,2.38,2.75
,,,,,,25.60,760,74.0,-20.3,00111110,26.01,760,36.1,2.38,2.86
,,,,,,26.51,760,74.0,-20.3,00111110,26.91,720,36.1,2.38,2.75
,,,,,,27.33,760,74.0,-19.5,00111110,27.82,760,35.3,2.38,2.83
,,,,,,28.22,760,74.0,-23.4,00111110,28.62,760,35.3,2.38,2.81
,,,,,,29.03,720,74.0,-23.4,00111110,29.42,720,36.8,2.38,2.83
1,,,,,,29.84,760,74.0,-21.9,00111110,30.24,760,36.1,2.38,2.94
,,,,,,30.62,760,74.0,-21.1,00111110,31.04,760,36.1,2.38,2.83
,,,,,,31.44,720,74.0,-20.3,00111110,31.84,720,36.1,2.38,2.78
,,,,,,32.25,760,75.0,-21.1,00111110,32.65,720,36.1,2.38,2.81
2,,,,,,33.05,760,75.0,-21.9,00111110,33.55,760,36.1,2.38,2.83
,,,,,,33.96,760,75.0,-21.9,00111110,34.36,720,36.8,2.38,3.03
,,,,,,34.86,720,75.0,-21.1,00111110,35.37,760,36.8,2.38,2.97
,,,,,,35.77,760,75.0,-18.8,00111110,36.17,760,36.8,2.38,2.94
,,,,,,36.57,760,75.0,-19.5,00111110,36.97,760,36.1,2.38,2.92
3,,,,,,37.37,760,75.0,-20.3,00111110,37.77,760,35.3,2.38,2.72
,,,,,,38.19,760,75.0,-19.5,00111110,38.59,760,35.3,2.38,2.83
,,,,,,38.99,760,75.0,-21.1,00111110,39.39,720,36.1,2.38,2.83
,,,,,,39.79,760,75.0,-21.1,00111110,40.19,720,36.1,2.38,2.78
,,,,,,40.59,760,75.0,-21.1,00111110,41.00,760,36.1,2.38,2.83
Monday,27,August,2012,13:45:45
,Group A:,'001,,,,Group B:,'001,,,,Group C:,'002
,,Engine Speed,Coolant,Lambda Control,Basic Setting,,Engine Speed,Coolant,Lambda Control,Basic Setting,,Engine Speed,Engine Load,Injection Timing,Mass Air Flow
,TIME,(G28),Temperature (G62),Bank 1,Requirements,TIME,(G28),Temperature (G62),Bank 1,Requirements,TIME,(G28),,,(G70)
Marker,STAMP, /min,°C,%,,STAMP, /min,°C,%,,STAMP, /min,%, ms, g/s
,0.00,720,85.0,-18.0,00111111,0.48,720,85.0,-20.3,00111111,0.90,720,36.1,2.38,2.81
,1.30,760,85.0,-19.5,00111111,1.71,720,85.0,-15.6,00111111,2.11,760,36.1,2.38,2.89
,2.51,760,85.0,-17.2,00111111,2.91,760,85.0,-20.3,00111111,3.31,720,36.1,2.38,2.75
,3.82,760,85.0,-20.3,00111111,4.32,720,85.0,-17.2,00111111,4.72,720,36.1,2.38,2.78
,5.12,760,85.0,-17.2,00111111,5.52,760,85.0,-19.5,00111111,5.94,720,36.1,2.38,2.78
,6.43,720,85.0,-18.0,00111111,6.83,720,85.0,-21.1,00111111,7.23,720,36.1,2.38,2.75
,7.63,720,85.0,-21.1,00111111,8.03,720,85.0,-17.2,00111111,8.45,760,36.1,2.38,2.81
,8.94,720,85.0,-16.4,00111111,9.45,720,85.0,-20.3,00111111,9.95,760,35.3,2.38,2.72
,10.35,720,85.0,-20.3,00111111,10.86,720,85.0,-21.1,00111111,11.25,760,35.3,2.38,2.75
,11.66,720,85.0,-21.1,00111111,12.06,720,85.0,-17.2,00111111,12.46,720,36.1,2.38,2.75
,12.86,720,85.0,-17.2,00111111,13.28,760,85.0,-20.3,00111111,13.77,760,35.3,2.38,2.75
,14.16,760,85.0,-20.3,00111111,14.57,720,85.0,-18.0,00111111,15.09,720,36.1,2.38,2.78
,15.58,720,86.0,-18.0,00111111,16.09,760,85.0,-17.2,00111111,16.57,760,35.3,2.38,2.78
,16.99,760,86.0,-17.2,00111111,17.50,720,86.0,-20.3,00111111,17.90,720,36.1,2.38,2.78
,18.30,720,86.0,-21.1,00111111,18.70,720,86.0,-18.0,00111111,19.10,720,36.1,2.38,2.81
,19.50,760,86.0,-17.2,00111111,19.90,720,86.0,-20.3,00111111,20.32,760,35.3,2.38,2.78
,20.72,720,86.0,-20.3,00111111,21.12,760,86.0,-18.0,00111111,21.52,760,35.3,2.38,2.75
,21.92,720,86.0,-18.8,00111111,22.32,760,86.0,-21.1,00111111,22.73,720,36.1,2.38,2.78
,23.21,720,86.0,-21.1,00111111,23.63,720,86.0,-18.0,00111111,24.03,720,36.1,2.38,2.81
,24.54,760,86.0,-20.3,00111111,24.94,720,86.0,-18.0,00111111,25.34,760,35.3,2.38,2.78
,25.72,720,86.0,-18.0,00111111,26.14,720,86.0,-21.9,00111111,26.54,720,36.1,2.38,2.75
,26.94,760,86.0,-20.3,00111111,27.36,720,86.0,-17.2,00111111,27.85,760,35.3,2.38,2.78
,28.36,720,86.0,-18.0,00111111,28.84,760,86.0,-21.1,00111111,29.26,720,36.1,2.38,2.75
,29.77,720,86.0,-18.0,00111111,30.17,720,86.0,-21.1,00111111,30.67,720,36.1,2.38,2.78
,31.07,760,86.0,-20.3,00111111,31.48,720,86.0,-18.0,00111111,31.88,720,36.1,2.04,2.72
,32.28,720,86.0,-18.0,00111111,32.68,760,86.0,-21.1,00111111,33.07,760,36.1,2.38,2.83
,33.48,760,87.0,-20.3,00111111,33.88,760,87.0,-18.0,00111111,34.30,720,35.3,2.04,2.75
,34.79,720,86.0,-18.8,00111111,35.19,720,87.0,-21.9,00111111,35.59,720,37.6,2.38,2.92
,35.99,720,86.0,-19.5,00111111,36.41,760,87.0,-15.6,00111111,36.91,760,37.6,2.38,3.17
,37.29,760,87.0,-16.4,00111111,37.71,760,87.0,-18.8,00111111,38.11,720,37.6,2.38,3.00
,38.52,720,87.0,-18.0,00111111,38.92,760,87.0,0.0,00100011,39.32,1520,60.9,5.78,17.58
,39.72,2000,87.0,15.6,00101001,40.12,1720,87.0,-3.1,00101011,40.63,1440,45.1,4.08,9.50
,41.03,1200,87.0,0.0,00110111,41.43,960,87.0,0.0,00110111,41.83,800,27.8,2.04,1.56
,42.23,720,87.0,-13.3,00111111,42.63,680,87.0,-18.0,00111111,43.03,680,36.1,2.04,2.53
,43.45,680,87.0,-24.2,00111111,43.94,720,87.0,-25.8,00111111,44.34,720,39.1,2.38,3.14
,44.86,960,87.0,2.3,00100011,45.26,1560,87.0,-7.0,00101011,45.66,1560,34.6,2.72,5.86
,46.15,1600,87.0,-15.6,00101011,46.66,1680,87.0,-16.4,00101011,47.06,1680,30.8,2.38,6.47
,47.46,1760,87.0,-14.8,00101011,47.86,1800,87.0,-3.9,00111011,48.26,1320,18.0,1.70,4.25
,48.68,1200,87.0,0.0,00100011,49.08,1440,87.0,3.9,00101011,49.48,1200,69.9,7.82,17.47
,49.88,1320,87.0,20.3,00101011,50.28,1400,87.0,18.8,00101011,50.79,1560,55.6,5.78,13.44
,51.19,1640,87.0,7.8,00101011,51.59,1680,87.0,10.2,00101011,51.99,1800,60.9,6.46,20.56
,52.39,1880,87.0,16.4,01101011,52.79,1960,87.0,14.1,01110011,53.19,1600,14.3,1.02,9.56
,53.61,1120,87.0,0.0,01110111,54.01,1240,87.0,1.6,01111111,54.41,1240,15.0,1.36,3.50
,54.90,1200,87.0,0.0,01110111,55.30,1120,87.0,0.0,01110111,55.72,1000,14.3,1.02,0.64
,56.20,920,87.0,0.0,01111111,56.61,760,87.0,7.8,01111111,57.01,600,39.1,4.08,3.89
,57.43,720,87.0,0.0,01110111,57.83,720,87.0,0.0,01110111,58.33,720,39.1,2.72,3.00
,58.73,760,87.0,-7.0,01111111,59.24,760,87.0,-18.0,01111111,59.64,720,34.6,2.38,2.81
,60.13,720,87.0,-23.4,01111111,60.53,720,87.0,-18.0,01111111,60.95,720,42.9,2.72,3.67
,61.35,760,87.0,-13.3,01111111,61.85,760,87.0,-13.3,01111111,62.25,840,47.4,5.44,8.17
,62.65,1360,88.0,0.0,01100011,63.06,1480,87.0,13.3,01101011,63.46,1280,42.9,3.74,6.97
,63.96,960,88.0,0.0,01110111,64.36,840,88.0,-1.6,01111111,64.76,720,28.6,2.04,2.11
,65.17,720,88.0,-19.5,01111111,65.57,680,88.0,-26.6,01111111,65.97,680,39.8,2.72,3.72
,66.37,720,88.0,-25.8,01111111,66.77,720,88.0,-18.0,01111111,67.17,1000,60.2,6.12,15.11
,67.57,1600,88.0,16.4,01100011,67.99,1440,88.0,6.3,01100011,68.39,1120,30.1,2.38,0.47
,68.79,1000,88.0,0.0,01110111,69.28,840,88.0,-11.7,01111111,69.70,720,30.8,2.04,2.50
,70.20,680,88.0,-19.5,01111111,70.69,760,88.0,0.0,01100011,71.11,1680,62.4,6.46,19.94
,71.51,1800,88.0,14.1,01100011,71.91,960,88.0,2.3,01100011,72.31,800,71.4,6.80,11.86
,72.71,1080,88.0,25.8,01101011,73.11,1320,88.0,18.8,01101011,73.51,1560,55.6,6.12,13.08
,73.92,1720,89.0,7.0,01101011,74.32,1920,89.0,7.8,01101011,74.72,2080,47.4,4.42,15.42
,75.12,2240,89.0,2.3,01101001,75.52,1880,89.0,0.0,01110111,76.04,1320,20.3,2.72,5.17
,76.44,1280,89.0,0.0,01100011,76.83,1400,89.0,-9.4,01101011,77.23,1440,53.4,5.44,14.14
,77.63,1480,89.0,8.6,01101011,78.03,1560,89.0,10.2,01101011,78.43,1600,46.6,4.42,10.75
,78.85,1640,89.0,1.6,01101011,79.35,1720,89.0,-5.5,01101011,79.75,1760,39.1,3.40,8.44
,80.15,1720,89.0,0.0,01110111,80.56,1720,89.0,0.0,01110111,81.06,1640,12.0,1.02,3.50
,81.46,1600,90.0,10.9,01111111,81.97,1520,89.0,0.0,01110111,82.45,1360,11.3,0.00,1.69
,82.87,1000,89.0,0.0,01110111,83.27,880,90.0,0.0,01110111,83.78,680,33.8,3.74,3.31
,84.18,680,90.0,-0.8,01111111,84.58,680,90.0,-5.5,01111111,84.98,760,37.6,2.72,2.67
,85.49,1560,90.0,0.0,01100011,85.89,1400,90.0,7.0,01101011,86.39,1520,42.9,4.08,8.17
,86.90,1520,90.0,-7.0,01101011,87.30,1560,90.0,-12.5,01101011,87.70,1600,48.1,4.42,13.31
,88.19,1720,90.0,3.9,01101011,88.59,1760,90.0,3.9,01101011,89.01,1840,42.9,3.74,11.53
,89.50,1520,90.0,0.0,01110111,89.90,1200,90.0,2.3,01110111,90.30,960,25.6,2.38,3.11
,90.70,800,90.0,0.0,01110111,91.12,720,90.0,0.0,01110111,91.62,720,33.1,2.38,2.25
,92.02,680,90.0,0.0,01110111,92.42,720,90.0,0.0,01110111,92.83,720,40.6,3.74,4.00
,93.33,1320,90.0,0.0,01100011,93.82,1080,90.0,14.1,01110111,94.24,920,27.1,2.38,0.00
,94.64,840,90.0,-3.9,01111111,95.04,760,90.0,-12.5,01111111,95.42,720,32.3,2.04,2.47
,95.84,720,90.0,-21.1,01111111,96.35,680,90.0,-24.2,01111111,96.75,720,39.8,2.38,3.14
,97.15,720,90.0,-19.5,01111111,97.55,760,90.0,-14.8,01111111,97.95,760,36.1,2.38,3.00
,98.46,760,90.0,-14.1,01111111,98.96,760,90.0,-14.1,01111111,99.36,760,32.3,2.04,2.50
,99.76,760,90.0,-16.4,01111111,100.16,720,90.0,-21.1,01111111,100.57,720,33.8,2.38,2.83
,100.97,720,90.0,-21.9,01111111,101.47,720,90.0,-18.0,01111111,101.87,760,33.8,2.04,2.64
,102.27,720,90.0,-15.6,01111111,102.69,760,90.0,-19.5,01111111,103.18,760,33.1,2.04,2.61
,103.58,760,90.0,-19.5,01111111,104.09,720,90.0,-17.2,01111111,104.59,720,33.1,2.04,2.53
,104.99,720,90.0,-21.1,01111111,105.39,720,90.0,-17.2,01111111,105.79,720,33.8,2.04,2.64
,106.21,720,90.0,-15.6,01111111,106.61,760,90.0,-18.8,01111111,106.99,760,33.1,2.04,2.67
,107.41,760,90.0,-19.5,01111111,107.81,720,90.0,-16.4,01111111,108.32,760,33.1,2.04,2.56
,108.72,720,90.0,-17.2,01111111,109.12,760,90.0,-20.3,01111111,109.52,720,33.8,2.38,2.64
,109.92,760,90.0,-20.3,01111111,110.32,720,90.0,-16.4,01111111,110.73,720,33.8,2.04,2.64
,111.12,720,90.0,-16.4,01111111,111.63,760,90.0,-19.5,01111111,112.14,760,33.1,2.04,2.64
,112.64,720,90.0,-17.2,01111111,113.04,720,90.0,-20.3,01111111,113.53,720,33.8,2.04,2.64
,114.03,720,90.0,-19.5,01111111,114.44,720,90.0,-16.4,01111111,114.92,760,33.8,2.04,2.67
,115.26,760,90.0,-16.4,01111111,115.76,720,90.0,-19.5,01111111,116.14,720,34.6,2.04,2.64
,116.56,720,90.0,-20.3,01111111,116.96,720,90.0,-17.2,01111111,117.36,760,33.8,2.04,2.67
,117.77,760,90.0,-16.4,01111111,118.17,720,90.0,-19.5,01111111,118.57,720,33.8,2.04,2.61
,118.97,720,90.0,-20.3,01111111,119.37,720,91.0,-17.2,01111111,119.77,720,34.6,2.04,2.64
,120.19,760,91.0,-16.4,01111111,120.59,760,90.0,-18.8,01111111,121.08,760,33.8,2.38,2.64
,121.60,720,91.0,-17.2,01111111,122.09,720,91.0,-20.3,01111111,122.49,720,34.6,2.38,2.67
,122.99,720,90.0,-18.8,01111111,123.40,760,91.0,-16.4,01111111,123.80,760,33.8,2.04,2.69
,124.30,760,91.0,-20.3,01111111,124.70,720,91.0,-18.0,01111111,125.11,760,34.6,2.38,2.69
,125.59,760,91.0,-17.2,01111111,126.01,760,91.0,-20.3,01111111,126.41,760,33.8,2.38,2.67
,126.83,720,91.0,-21.1,01111111,127.32,720,91.0,-18.0,01111111,127.71,720,33.8,2.04,2.64
,128.12,720,91.0,-17.2,01111111,128.63,760,91.0,-19.5,01111111,129.13,760,33.8,2.04,2.69
,129.53,760,91.0,-17.2,01111111,129.93,720,90.0,-20.3,01111111,130.35,720,33.8,2.04,2.67
,130.75,720,91.0,-20.3,01111111,131.15,720,91.0,-16.4,01111111,131.53,720,34.6,2.38,2.67
,131.95,760,91.0,-15.6,01111111,132.46,760,91.0,-19.5,01111111,132.94,720,33.8,2.04,2.58
,133.35,720,91.0,-21.1,01111111,133.75,720,91.0,-17.2,01111111,134.15,720,34.6,2.04,2.69
,134.57,720,91.0,-16.4,01111111,135.05,720,91.0,-19.5,01111111,135.46,760,33.8,2.38,2.67
,135.86,760,91.0,-19.5,01111111,136.26,720,91.0,-17.2,01111111,136.68,720,33.8,2.04,2.64
,137.08,720,91.0,-17.2,01111111,137.58,720,91.0,-16.4,01111111,138.07,760,34.6,2.04,2.67
,138.49,760,91.0,-16.4,01111111,138.89,760,91.0,-20.3,01111111,139.38,720,34.6,2.38,2.64
,139.78,720,91.0,-20.3,01111111,140.20,720,91.0,-17.2,01111111,140.60,720,34.6,2.04,2.69
,141.00,760,91.0,-16.4,01111111,141.40,760,91.0,-19.5,01111111,141.80,720,33.8,2.38,2.72
,142.20,760,91.0,-21.1,01111111,142.62,760,91.0,-18.0,01111111,143.11,720,33.8,2.04,2.67
,143.51,720,91.0,-18.0,01111111,144.01,720,91.0,-16.4,01111111,144.42,760,33.8,2.38,2.67
,144.82,760,91.0,-16.4,01111111,145.22,720,91.0,-20.3,01111111,145.62,720,33.8,2.04,2.64
,146.14,720,91.0,-19.5,01111111,146.52,720,91.0,-16.4,01111111,146.94,760,33.8,2.04,2.69
,147.43,760,91.0,-16.4,01111111,147.83,720,91.0,-20.3,01111111,148.25,720,33.8,2.04,2.64
,148.73,720,91.0,-20.3,01111111,149.14,760,92.0,-17.2,01111111,149.65,760,34.6,2.38,2.67
,150.15,760,91.0,-19.5,01111111,150.55,720,92.0,-17.2,01111111,150.95,760,33.8,2.04,2.64
,151.35,720,91.0,-17.2,01111111,151.77,760,92.0,-20.3,01111111,152.15,720,33.8,2.04,2.64
,152.57,720,91.0,-20.3,01111111,152.97,760,91.0,-16.4,01111111,153.37,760,33.8,2.04,2.67
,153.77,720,92.0,-16.4,01111111,154.18,720,92.0,-19.5,01111111,154.58,720,33.8,2.04,2.61
,154.98,760,92.0,-19.5,01111111,155.38,720,91.0,-16.4,01111111,155.78,760,33.8,2.04,2.69
,156.29,720,91.0,-17.2,01111111,156.69,720,92.0,-21.1,01111111,157.09,720,34.6,2.38,2.72
,157.59,720,92.0,-19.5,01111111,158.10,720,92.0,-19.5,01111111,158.50,760,33.8,2.04,2.64
Then I did a rescan afterwards...
And Dan.. you can download it for FREE here..
http://www.ross-tech.com/vcds-lite/download/index.html
and you will need the ebay cable found here..
http://www.ebay.co.uk/itm/USB-409-1-KKL-VAG-COM-OBD-2-II-VW-AUDI-SKODA-SEAT-DIAGNOSTIC-Cable-UK-/261078372642?pt=UK_Diagnostic_Tools_Equipment&hash=item3cc97bd122
Offline Dalo Harkin
« Reply #8 on: 27 August 2012, 14:39 »
Nino, how have you configured the boost tubing to the DV?
do you have a boost gauge? is it 'T' into something else?
Check all the pipes, if needed for now to test just run one off the plenum direct to the DV
Offline Nino
« Reply #9 on: 27 August 2012, 14:51 »
  • how have you configured the boost tubing to the DV? - Its all the standard tubing not changed anything
  • do you have a boost gauge? - No
  • is it 'T' into something else? - What do you mean by this?
  • Check all the pipes - I have checked all that people say to check and cannot see any splits/cracks or holes
  • if needed for now to test just run one off the plenum direct to the DV - What do yu mean by this?
« Last Edit: 27 August 2012, 14:53 by Nino »
