Author Topic: fault code 17586 help needed  (Read 12314 times)
Offline birch
« on: 26 August 2012, 12:21 »
i have a fault code reader and my engine management light has come on and i read code 17586, i cleared the code and light came on again 17598, if i clear the code i get either one of the two codes coming back, neither of these codes appear in my code list that came with the scanner, seem to be something to do with 'linear 02 sensor' any advice would be really appreciated, thanks.
« Last Edit: 22 September 2012, 17:56 by birch »
Offline barrym381
Re: fault code help needed
« Reply #1 on: 26 August 2012, 12:28 »
sounds like a lambda sensor sure that was same code i had on a leon a while ago
Offline birch
« Reply #2 on: 26 August 2012, 12:40 »
any idea which of the two lamdas mate?
Offline barrym381
« Reply #3 on: 26 August 2012, 12:48 »
not sure but can find out when im home in a day or 2 :smiley:
Offline birch
« Reply #4 on: 31 August 2012, 08:49 »
update, same code comes up if i delete and rescan,  17586 P1178 linear o2 sensor pump current open circuit,   any advice would be much appreciated, thanks.
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
« Reply #5 on: 31 August 2012, 09:48 »
Look in here mate - will give you a list of codes, what they mean, how possible fixes.
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
Mk4 Gti - Gone but not forgotten!
Offline birch
« Reply #6 on: 31 August 2012, 18:08 »
i already looked in the rosstech list and not on there and its not on the list of dtc's that came with my scanner either, seems to be very little information about this code!
« Last Edit: 31 August 2012, 18:32 by birch »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 31 August 2012, 19:57 »
Offline birch
Re: fault code 17586 help needed
« Reply #8 on: 22 September 2012, 17:56 »
you were right mate, 17586 fault code was precat lambda, thanks.
