Author Topic: Engine cutting out while driving  (Read 3463 times)
Offline MrRogers
« on: 25 August 2012, 20:22 »
Evening all,
Iv recently had a oil leak so not been driving the golf for a while and i had the rocker gasket changed yesterday as apparently this was the problem since this iv been taking it out for a spin last night engine cut out completely atleast 3-4 times while in motion and lost all power (very dangerous on a busy road) and wouldnt start again for 10 mins or so. I scanned the car for faults this morning and it brought up something to do with the battery so i replaced the battery this morning taken it out for another spin again and after 20 mins of driving cut out on me twice but this time before it cut out i got the "STOP oil pressure" light.
Is there anything that the garage may have forgotten to do while changing the gasket? Maybe air has gotten into the system some how? Ill be straight on the phone to them Tues morning but i thought i could get a heads up before hand.
Thanks all.
« Last Edit: 25 August 2012, 20:24 by MrRogers »
2000 Golf MK4 1.8 AGU black magic, Custom Code stage 1 remap, Forge 008, Simota Aeroform CAI, G60/VR6 Combo, Weitec GT Hicon coilovers, Golf GTI MK5 18" Monza style alloys, 10mm H&R spacers front + 20mm H&R spacers rear, OEM Polo MK5 aerial, Whiteline front ARB + Whiteline droplinks.
Offline james2
  • No scammers please.
Re: Engine cutting out while driving
« Reply #1 on: 25 August 2012, 21:03 »
Sounds like alternator/battery.Check how many volts its getting with engine running (13.5v think). I had a problem years ago, sounds like yours. Also have a look around what they changed ,oil leaks or a trapped wire.Its easy done.  :lipsrsealed:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline MrRogers
« Reply #2 on: 26 August 2012, 12:54 »
Thats wat i thought but iv had the alternator changed about 3 months ago as i cut out driving down the motorway and lost all power. Replaced the battery yesterday as i thought it was the battery but still cutting out on me. Whats intresting as the "STOP oil preasure" light came on ill have to go and have a nosey around :(
Offline Chris#101
« Reply #3 on: 26 August 2012, 14:59 »
Maf possibly?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline MrRogers
« Reply #4 on: 26 August 2012, 21:46 »
Ill give that a shot 2mro unplug it and let it run for a while and see if it cuts out. Oh yeah saying that it didnt just cut out while driving when left idling for about 15-20 mins it cut out aswel. Even if its the maf could it cause the oil warning light to come on? Thanks again gents.
Offline Nino
« Reply #5 on: 26 August 2012, 22:32 »
Crank sensor?
Current - MK6 GTi Edition 35
Offline simon_709
« Reply #6 on: 27 August 2012, 00:17 »
The oil light sounds like the oil pick up pipe could be blocked if the oil pressure light is coming on..so would def be worth checking that. And the cutting out could be a faulty alternator because I recently had a simular problem, is ur battery light coming on the dash?
My Golf GTi, RS4 reps 17", coilovers, tinted windows, De-cat and middle box removed with 3" oval back box, stage 1 Revo re map, G60 flywheel/VR6 clutch, HID kit, Forge 007p,
Offline MrRogers
« Reply #7 on: 27 August 2012, 11:24 »
Yes mate the oil light and the battery light comes on then when you try turning it over the battery and oil light stay on wait 10-15 mins then it starts up gonna give it another scan now. I did think about the pickup pipe playing up aswel. One fault after another joys of a mk4 lol.
Offline james2
« Reply #8 on: 28 August 2012, 18:48 »
Does the battery warning light come on before it stalls. Does it only stall once its up to running temp ?
