Author Topic: New Cat Convertor  (Read 808 times)
Offline bullzeye
New Cat Convertor
« on: 25 August 2012, 16:25 »
Recently my car had a horrible smell coming from the exhaust like a sulphur smell. so i been and had a new Cat fitted today. the mechanic said he can still smell fuel coming from the exhaust and it will burn this cat out if i dont sort it
Any ideas what will be causing it? theres no error codes form code reader or anything. This may also explain mt poor mpg as i seem to get less than u lot :P
cheapest mobile provider arround order a free sim with £5 credit www.giffgaff.com/orders/affiliate/s3cr3t
Offline Chris.
Re: New Cat Convertor
« Reply #1 on: 25 August 2012, 16:44 »
What engine code?
Any fault codes?
Click For Build Thread
Offline bullzeye
« Reply #2 on: 25 August 2012, 16:47 »
no mate no fault codes  :sad:  its AGU
« Last Edit: 25 August 2012, 16:53 by bullzeye »
Offline Chris.
« Reply #3 on: 25 August 2012, 17:34 »
What MPG are you getting? MAF and lambda primarily control fuelling.
Offline bullzeye
« Reply #4 on: 25 August 2012, 17:57 »
normal short journey driving wont usually see over 26mpg, ive owned it nearly 2 years and highest ive seen it go is 35mpg on 100 mile trip on the motorway but was trying hard to get that
wouldnt maf or lambda send a code?
Offline Chris.
« Reply #5 on: 25 August 2012, 18:00 »
MAF typically dont if they under or over reading....only method is to log.
Offline bullzeye
« Reply #6 on: 25 August 2012, 18:09 »
ok so i need someone with vagcom in preston area :( local garages are poop at anything code like
