Author Topic: golf trip computer  (Read 2685 times)
Offline luke300586
golf trip computer
« on: 25 August 2012, 14:41 »
my current golf dosent have the trip computer on the clocks like my old one did,  is it possible to put one on if so what would this include thanks
Offline km
Re: golf trip computer
« Reply #1 on: 25 August 2012, 14:44 »
you mean the mfd display? you can get new clocks coded
Offline luke300586
« Reply #2 on: 25 August 2012, 14:46 »
so ill need a set of clocks with the display and a stalk?
Offline km
« Reply #3 on: 25 August 2012, 14:50 »
here's more info.
http://uk-mkivs.net/forums/t/167146.aspx
My car doesn't have a multi function display, can I fit a set of clock with the display?
"Yes you can but you will need a new wiper stalk (4B0 953 503 H) with the computer controls on it and then it will need wiring into the green multi plug connector on the rear of the rear of the clocks. Also if you currently don't have the outside temperature probe that is located in the bumper you will need to install one and wire it back to the green connector (pin 26) for the cluster to display the outside temperature."
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 25 August 2012, 15:19 »
Just done this, ask away if you don't find any of the info you need in that link  :wink:
Offline luke300586
« Reply #5 on: 25 August 2012, 15:55 »
cheers so
-can i use any type of clocks ie bora golf with the big mfd or small mfd display
-are the clocks easy to take out and replace
-can i change the milage to whats on my clocks
it seems plug and play really?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 25 August 2012, 18:14 »
the clocks will need coding to your ECU/keys as the immobiliser needs syncing. This is done through VAG COM. You will also need to extract the SKC from possibly both clusters and the mileage will need adjusting. This is done with VAG TACHO. You'll also need to fit some new wires from the wiper stalk to the cluster multi plug and also a wire from the multi plug to the bumper for the outside temp sensor.
Clocks are easy to pull out and change over, wiring is a bit fiddly and wiper stalk is a PITA as you've got to take the steering wheel and other bits off to get to it. Coding the clocks/keys is a bit tricky first time you do it but easy enough once you know your way round it all
Offline luke300586
« Reply #7 on: 25 August 2012, 18:16 »
how much will all the re coding and this vag stuff cost
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 25 August 2012, 18:26 »
probably only beer tokens for someone who has the stuff on their computer. I'm assuming yours is immo2 as you don't have a display, what year is your car?
Offline luke300586
« Reply #9 on: 25 August 2012, 18:33 »
whats immo2? its a 2000 or 2001 no had the display in my old car along with central locking on the key fod which this dosent so looking to get both put in
