Author Topic: Leaking Coolant  (Read 1290 times)
Offline robw09
Leaking Coolant
« on: 24 August 2012, 22:49 »
Been leaking some coolant slowly over the past week and have isolated to around where the metal pipe goes into engine block to the side of oil filter.
Couple of questions....
Is the leak going to be anything other than the metal pipe has a problem?
Is the pipe easy enough to replace myself?  To me it looks i will have to take the oil filter off, but maybe wrong.
Should I may as well buy a replacement pipe before I start taking the old one off?
Ta
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Leaking Coolant
« Reply #1 on: 25 August 2012, 01:03 »
8V yeah!!
Can do it with the filter on but it's a b!tch of a job....
AFAIK Replacement is NLA but try VW Classic...
For More Info Click To See;
Offline Jimmyrallye
  • 20vt goodness
Re: Leaking Coolant
« Reply #2 on: 25 August 2012, 21:41 »
Goodluck with that buddy i had a coolant leak started of with that metal pipe ..then had to change expansion bottle and cap and now ive just changed waterpump its all looking good so far :)
Offline robw09
Re: Leaking Coolant
« Reply #3 on: 25 August 2012, 23:15 »
So, is it only going to be metal pipe?  And is a replacement the only option....it is only around £15, but still....
Quote
Just looking mad me wince  :angry: How does it attach on to the engine block? Just wondered whether it was a garage or DIY job  :undecided:
Quote
I know you like VW original parts, but I think I am forced into a GSF or other such source this time!
Quote
I should be ok, recently changed most of coolant parts.  :tongue:
Ta
Offline oakgreener
Re: Leaking Coolant
« Reply #4 on: 25 August 2012, 23:46 »
I replaced mine a couple of months ago with this one
http://www.ebay.co.uk/itm/COOLANT-PIPE-METAL-GOLF-JETTA-MK-TOLEDO-MK1-1-6-1-8-1-6i-1-8i-/390459174988?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=M#ht_1328wt_952
Not an easy job but do-able. Take the oil filter off. Much easier.
It's fixed to the block with two or three 6mm nuts and a 6mm screw.
