Author Topic: 17704 code??  (Read 2167 times)
Offline spetzdude
  • I Bleed Blue!
17704 code??
« on: 24 August 2012, 20:30 »
Evening all,
Got my car scanned today thanks to AD1.8T and broght up a 17704 code.
I have allready replaced the temp sender but the ecu light keeps returning
Im getting a slight missfires when boosting at 20PSI but not sure if thats got anything to do with it.....
What else could be the problem, could it be the thermostat??
Performance mods: Revo stage 2 map, 5 Peice Hose Kit, TIP, evoloution motorsport air filter, N249 by-pass, Forge spliter valve, lowerd 50mm (KW), Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
Cosmetic mods: Tints,De-wiperd the rear, De-badged front grill, Sharan rear badge, Rear spoiler, 4mo rear valance, 4mo front spliter, arero wipers, stubby areial, DOTZ 18" Alloys, Boost guage, Smoothed Bumbers, ECS N75 Vlalve.
BHP: 231
TRQ: 341.3
Offline Nino
Re: 17704 code??
« Reply #1 on: 24 August 2012, 20:44 »
I had this issue and code, I replaced both the G62 temp sensor and the termo, and mine was ok after that, I would highly rekconmend you use VAG parts thou DO NOT use euro car parts termos/sensors there crap and will break.
Also take a read of this (From ross tech)
 17704/P1296/004758 - Error in Mapped Cooling System
Possible Symptoms
    Cold start issues
Possible Causes
    Coolant Temperature Sensor (G62) faulty
    Coolant Thermostat faulty
Possible Solutions
    Check Coolant Temperature Sensor (G62)
    Check Coolant Thermostat
Special Notes
    Check the stored Freeze Frame data with this fault code. Freeze Frame information will be found in the fault code description (if the module supports it) or in Generic OBD-II if the vehicle complies with those regulations.
        Freeze Frame data stored at -40*C is generally an indication of a faulty ECT or wiring.
        Freeze Frame data stored at +140*C is generally an indication of a faulty ECT or wiring.
        Freeze Frame data stored with in the 68*C ~ 80*C range is an indication that the vehicle was close to, but not within, the cooling systems normal operation range. The Thermostat itself or Cooling system components may be at fault.
Current - MK6 GTi Edition 35
Offline spetzdude
  • I Bleed Blue!
Re: 17704 code??
« Reply #2 on: 24 August 2012, 21:27 »
Did you change the thermostat yourself??
BHP: 231
TRQ: 341.3
Offline AD1.8T
Re: 17704 code??
« Reply #3 on: 24 August 2012, 21:54 »
Just read the how to bud looks pretty straight forward to be fair alot easier than doing it on my old zr !
Offline Nino
Re: 17704 code??
« Reply #4 on: 24 August 2012, 22:47 »
Yes abit fiddly getting to the bottom bolt (be careful not to round it off) but yes I did it myself.
