Author Topic: New wheel fitment dimensions help  (Read 1058 times)
Offline Chris#101
« on: 24 August 2012, 12:46 »
Howdo might of found a new set of wheels, the spec is 18x8.5j et44 running 205/40/18 tyres. What spacers size will I require to get flush tyres to arches and.to avoid scrub ??
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Chris#101
Re: New wheel fitment dimensions help
« Reply #1 on: 24 August 2012, 19:39 »
any wheel gurus out there?
Offline turbokid23
« Reply #2 on: 24 August 2012, 20:45 »
Mate mine am 8.5j all round with no spacers but flush I would say 5 on front and 10 on rear
Offline cullygti
« Reply #3 on: 24 August 2012, 20:49 »
different et to yours tho dude  :wink:
Offline turbokid23
« Reply #4 on: 24 August 2012, 20:56 »
Just seen it haha I'm having a blond moment
Offline cullygti
« Reply #5 on: 24 August 2012, 20:58 »
 :lipsrsealed:  :grin:
Offline GunnerCP
« Reply #6 on: 24 August 2012, 23:07 »
Youd want something like 25mm or 30mm rears and 20mm or 25mm fronts depending on how low and the exact look you want. I think either would look ok tho.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 25 August 2012, 00:24 »
I'd say 20 front (final offset of ET24) and 30 rear (final offset of ET14)
