Author Topic: Rcd510 - installation  (Read 4206 times)
Offline Ginge 35Edition
« on: 24 August 2012, 06:37 »
Morning all, I'm going to be installing the above today. Any tips or things to watch out for?
Offline Raffe
Re: Rcd510 - installation
« Reply #1 on: 24 August 2012, 07:18 »
Damaging the dash as you pry the trim fascia off, go careful with something made of plastic :wink:
« Reply #2 on: 24 August 2012, 07:24 »
We've got to pick the wife's cab up in a bit so I'm tempted to make cheeky request and get the dealer to do it.
Offline Jimble
« Reply #3 on: 24 August 2012, 08:23 »
Might be worth it, if there is a tech free it should only take a couple of minutes cos it won't need coding.
Offline ScottA
« Reply #4 on: 24 August 2012, 08:51 »
Just do it yourself, you're not going to damage the trim if you're careful, use a cloth around a knife or something to get it off. What if VW damage it? They're probably less likely to care than you are. If they're doing it as a favour, I doubt you could get them to replace anything they damage either.
If I was at home I would screenshot Elsa which shows where the clips are located for the trim. It's fairly straightforward though. I wouldn't be afraid of pulling it. I don't think it's exactly expensive to replace if you break any clips, it's the dash you've gotta watch you don't damage.
Offline mike.
« Reply #5 on: 24 August 2012, 09:13 »
There is a picture on THIS page showing the clips.
If you could get some plastic trim tools that would be the best bet. You can get them on Ebay for a couple of pounds.
« Last Edit: 24 August 2012, 09:16 by mike. »
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
« Reply #6 on: 24 August 2012, 09:38 »
Thanks all of you! Here goes!!!!!
Offline Mr GTD
« Reply #7 on: 24 August 2012, 10:14 »
Good luck, be sure to report back!!
« Reply #8 on: 24 August 2012, 11:00 »
20 mins later and job done! Really pleased just got to check sd slot now.
Offline ScottA
« Reply #9 on: 24 August 2012, 11:15 »
 :cool:
