Author Topic: Air Mass Valve Cap?  (Read 883 times)
Offline Rob Zombie
Air Mass Valve Cap?
« on: 23 August 2012, 21:11 »
Evening All
Basically I've had a little issue with my girl last weekend...
I've got a Rotrex Supercharger fitted however for some reason the bolts sheered off causing the alternator & power steering belt to fly off... this also cause the air mass valve to bounce about a bit!
Problem i have is the air mass valve cap fell off as i was driving and a car drove over it....:(
Can anyone suggest where i can find a replacement or if there's anything i can do for a long term work around?
Thanks in advance
Robb
« Last Edit: 23 August 2012, 21:14 by Rob Zombie »
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
