Golf mk2
Fitting emob switch to car
Topic: Fitting emob switch to car (Read 1173 times)
stainesy
im not a master debater but i'm a cunning linguist
23 August 2012, 19:31 »
Ok now I have my very basic 1985 jetta I want to fit an imob switch hidden somewhere as it has no alarm or anything other that a clamp on steering lock.
What's the best way to go about this?
I'm guessing I bypass one of the ignition wires to a switch somewhere?
Gambit
Forum addict
Re: Fitting emob switch to car
23 August 2012, 20:41 »
The correct way to do it is via the back of the fuse box, the cheap way is via ignition switch live. Any car crim worth their salt will bypass an immobiliser wired through ignition live
weazgti
23 August 2012, 22:02 »
Or they would look on here and know you ve wired it through fuse box
oakgreener
GTI forum regular
24 August 2012, 10:11 »
You could use a double pole switch and break into the coil feed wire on one pole of the switch, and into the starter solenoid trigger wire on the other pole. Of course, any of this can be hot wired, but you have to believe that the type of little sh!! liable to nick the car won't have the sense to get over this
Good luck anyhow
SoundillusioN
10k hero
24 August 2012, 13:12 »
Ignition coil live via rear of fusebox, cars with fuel pumps should have that killed too. Personally I wouldn't skimp, if you're worried get a security system but fit it yourself as in my experience alarm fitters have no respect.
Shaun
Now with added MK7
Forum Member Map
Mk1 Project Clicky
Mk1 Dub Rides Clicky
T25 Project Clicky
T25 Dub Rides Clicky
Golf mk2
