Author Topic: Vr6 motor from carado into mk3 vr6?  (Read 2362 times)
Offline Outlawsaffa1982
« on: 23 August 2012, 12:40 »
Hi lads,
I'm curious... Will the motor from a carado (vr6) fit into my mk3 vr6? Ie, mountings and wiring all the same?
Offline benvictors
  • bgk Tuning - coming soon!!!
Re: Vr6 motor from carado into mk3 vr6?
« Reply #1 on: 23 August 2012, 12:48 »
You will need the ecu and engine loom aswell as the engine. Can i ask why you would want to do this swap?
Offline Len
« Reply #2 on: 23 August 2012, 13:11 »
It is a 2.9 instead of 2.8.
www.sas.org.uk
www.the-ace.org.uk
« Reply #3 on: 23 August 2012, 13:14 »
Well a knock has devolved in my vr6 when I start her from cold, so I figure il check out my options before I do anything. Also the carado I believe is 190bhp... Extra 20bhp would be nice
Offline robo22sri
« Reply #4 on: 23 August 2012, 13:20 »
CORRADO! argh  :rolleyes:
Offline Ess_Three
« Reply #5 on: 23 August 2012, 22:39 »
The extra cc isn't even 100.
It's only 50ish IIRC.
And it gives very little of the power gain...
The ABV upper inlet manifold and TB give the majority of the gain.
They are a good upgrade to an AAA VR6, as long as it's an early one...the so called OBD1 type.
Also, the head gasket from a US Mk4 VR6 is a good addition. It takes the CR up from 10.0:1 to 10.5:1.
That, plus the ABV upper manifold and TB will give a mapped AAA as much power (if not more) than a ABV, but without the added 'Corrado VR6' tax often applied to the ABV engines.
..but gaining motorcycles.
Offline AudiA8Quattro
« Reply #6 on: 24 August 2012, 09:53 »
The two engines are 2792cc and 2861cc, not a huge difference  :smiley:
Offline kahunajb
« Reply #7 on: 24 August 2012, 10:26 »
How does changing the head gasket alter the CR?
Mk1 Leon Cupra TDI - Keeping
Mk5 Golf GTI - Revo Stage 1 - FOR SALE £5,250
Mk3 GTI 16v Anniversary - OEM+ - Gone :(
Mk4 GTI 2.0 - Slow - Good Riddance
« Reply #8 on: 24 August 2012, 10:31 »
Depends on thickness of gasket..
Offline kahunajb
« Reply #9 on: 24 August 2012, 10:55 »
Thought so it's like a spacer plate then similar to when you reduce the compression when you turbo a vr?
