Author Topic: Group Buy - Golf MK5 / MK6 Custom 10" Subwoofer Enclosure  (Read 4414 times)
Offline jedi-knight83
Am I allowed to post details of a group buy I'm running on a couple of other forums?
For a 10" sub enclosure.
Tornado Red Golf GTI - R-Tech Stage1, Milltek, RCD510DAB, H&R Springs & Rear ARB, WALK, 19" BBS CH, ED30 everything, ICE - Build thread
Reflex Silver Caddy TDI - Stage1, 19" S8 alloys, Coilovers, GTI Steering Wheel - Build thread
Cambridge Autogleam Facebook
Offline The Doc
  • E63s Estate - Vito Sport
Re: Group Buy - Golf MK5 / MK6 Custom 10" Subwoofer Enclosure
« Reply #1 on: 22 August 2012, 21:23 »
Of course, just needs to be in the group buy section  :wink:
I'd advise you to say a little about yourself and a price would help  :smiley:
Offline Raffe
« Reply #2 on: 22 August 2012, 21:51 »
Is it possible to run a sub and amp off of a standard RCD510 and what cc is the box, has it been designed to work with a specific speaker brand?
Offline Mr GTD
« Reply #3 on: 22 August 2012, 21:51 »
Yep and this what I advised in his thread on the welcome section :wink:
« Reply #4 on: 22 August 2012, 22:12 »
Hi.
indeed.. I have all the details and price etc. But didnt want to storm on and post them all straight away if there was someone to ask first.
Regarding myself... New to this forum but very active on other VW forums..
http://www.mk5golfgti.co.uk/forum/index.php/topic,35270.0.html
« Reply #5 on: 22 August 2012, 22:15 »
You have to run a line out converted from an rcd510 (i have an rcd510 DAB myself so I know it works)
The cheap way is to get a £15 LOC and tap the rear speakers and run a sub from there. Then you can adjust sub level by adjusting front / rear fade.
The expensive way (which i've just done) is with something like an Audiocontrol LC2i. This give a strong clean pre out for front speakers and also a bass output. You can also run a bass control remote dial off this unit.
This is then feeding my JL HD600/4 amp which in turn is running front components and a sub in the rear.
« Reply #6 on: 22 August 2012, 22:29 »
Sorry.. saw the other question..
the box is 0.66cu.ft / 18.68l. Max sub depth is 6" with a magnet diameter or 6" although you could fit an extra MDF ring to the front and bolt the sub to that which would give you a bit extra depth.
The biggest sub they have tested is the JL 10w3v3 which fits and also sounds 'amazing'.. which is handy as this is the sub i have :)
Offline Raffe
« Reply #7 on: 23 August 2012, 08:52 »
Brilliant thanks for reply, could be interested :cool:
« Last Edit: 23 August 2012, 12:34 by Raffe »
« Reply #8 on: 24 August 2012, 00:14 »
then can also make it with an 8" mounting ring instead of 10"
let me know if you want to go ahead.
Its £160 posted from america (usually £198) so its a good discount. I was getting quotes of £180-£220 for getting a box built here and they didnt look as nice as this one.
Offline Raffe
« Reply #9 on: 24 August 2012, 07:17 »
Does it come fully assembled and trimmed as per the photo?
Are there any connection terminals included in the box?
Is that price delivered to home address?
Just want to be clear on the product, thx.
