Author Topic: golf mk4 help :(  (Read 1167 times)
Offline GTIcheeseman
golf mk4 help :(
« on: 21 August 2012, 17:22 »
Right I'm selling my car and got home tonight after worked turned it off then hour later went out unlocked it, ignition turned on but it just kept turning over and wouldn't fire up, done this with spare key same thing...
No fault codes
Got it to start but when I rev it all drops down splutters then revs normal, I will try to upload a video
Need help asap
Re: golf mk4 help :(
« Reply #1 on: 21 August 2012, 17:31 »
Forgot to add its a mk4 1.8t agu 99
Had cam and crank sensor replaced
Offline GunnerCP
« Reply #2 on: 21 August 2012, 17:41 »
Ignition amp? Where in the country are you?
« Reply #3 on: 21 August 2012, 17:47 »
Kent, bromley
I can't cope with anything going wrong! :'(
Offline Reesy23
« Reply #4 on: 21 August 2012, 17:47 »
+1 On the ignition amp.
« Reply #5 on: 21 August 2012, 17:49 »
Ffs! Really? Could it be that, it finally started but just don't rev from idle properly
I can't be doing speeding more money on it I need it gone
Offline GunnerCP
« Reply #6 on: 21 August 2012, 18:10 »
Ignition amp or hose popped off (I had something similar when a boost hose popped off)
« Reply #7 on: 21 August 2012, 18:14 »
I haven't even reved it. I just got in from work turned it off then half hour and turned it on and nothing
Offline Chris.
« Reply #8 on: 21 August 2012, 20:19 »
Ive had a pipe off that causes AGU to not start :S
ignition amp usually causes it to run on 3 pots most commonly.
Click For Build Thread
« Reply #9 on: 21 August 2012, 21:23 »
Went out few hours later bang first time
