Author Topic: What's the blue wire on the alternator for?  (Read 2188 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 04 July 2005, 11:50 »
As above :)
Just got a new alternator to soloniod made up and just wondered what the thin blue wire was for?
cheers
Offline Overseer
Re: What's the blue wire on the alternator for?
« Reply #1 on: 04 July 2005, 12:00 »
IIRC its the one that is live when the alternator is charging.. as people run split-charge relay activation things off this
Offline Deefadog
« Reply #2 on: 04 July 2005, 12:08 »
Cheers, can't hold much though, it's only about a 5amp cable?
Judderi
« Reply #3 on: 04 July 2005, 13:31 »
I think its used for the battery warning light on the dash. Un-plug it and the light should come on if the cars running. It has a spade connector near to the battery.
Offline tobz.
« Reply #4 on: 04 July 2005, 13:36 »
Yep it is the charge-light signal cable.
You can't draw any current from it though, if you try to draw more than about 150mA the battery light on your dash will remain on when the engine is running. In the case of a split charging system the blue wire is used to switch a relay which supplies the charging current to the second battery.
You got any pics of your dad's split ?
Offline Deefadog
« Reply #5 on: 04 July 2005, 13:38 »
Nice one guyz! Learning all the engine bits one by one :)
Now what's that big shiney metal thing in the middle? lol
Offline monzablue16v
« Reply #6 on: 04 July 2005, 15:27 »
I think thats an expensive bit don't touch it!
Offline Deefadog
« Reply #7 on: 04 July 2005, 20:48 »
 :grin:
