Author Topic: After mk4 adjustable drop links  (Read 3958 times)
Offline Mk2_tel
« on: 19 August 2012, 20:45 »
Where can I get these from? There for my 5door
Tdi 2001 plate. Fitting Coilovers this week been told
To use these and get away with not fitting a anti roll
Bar off a tt as I'm not going really low this correct?
Offline dub_fan
Re: After mk4 adjustable drop links
« Reply #1 on: 22 August 2012, 22:13 »
Hi mate. Iv always had my adjustable drop links from veedubmachine.co.uk for about £20. I have always ended up fitting arb with bigger hoops also as still rubs even though not stupidly low. Best thing iv found to do if your leaving standard arb on is to remove the lock nut from the adjustable links and wind them as small as they go as silly as it sounds as you get more clearance lol
....Project 1.8t Bolf-watch this space :) ....
Offline Prawny
  • R-tech power!!!
« Reply #2 on: 23 August 2012, 08:37 »
yup, contrary to popular belief, adjustable drop links do not stop the rubbing issue at all.
Best solution is to run an S3/TT/LCR front arb which goes under the shaft and can be bought for less than £50, then mount these to your existing drop links using slightly longer bolts and a few washers / spacers to keep the drop link vertical and save wearing out the bushes.
Offline GTi_James
« Reply #3 on: 23 August 2012, 08:47 »
phoned up my local Audi shop and the ARB is now at £80ish includes VAT
Offline Prawny
  • R-tech power!!!
« Reply #4 on: 23 August 2012, 09:09 »
is that brand new? that's cheap!
I was actually referring to second hand ebay prices, but if they're only £80ish from the dealer I'd do that!
Nice find mate :)
Offline GTi_James
« Reply #5 on: 23 August 2012, 09:13 »
Nice find mate :)
 :wink: dont forget your spacers and drop links
Offline Prawny
  • R-tech power!!!
« Reply #6 on: 23 August 2012, 10:13 »
I don't need any of that kit matey, I've got a full R32 front end setup with eibach R32 bar and drop links.
What I meant was, if I had the choice between a second hand bar at £50 and a new one at £80, i'd take the new one myself.
Offline GTi_James
« Reply #7 on: 23 August 2012, 10:21 »
well blow me down lol awesome stuff then, yeah you should be rearing to go with that and if you wanted the R32 from the stealers theyre asking for £109ish for the bar but not sure if that includes VAT :undecided:
