Author Topic: mk3 vento headlights into a golf  (Read 2422 times)
Offline robjackson
« on: 19 August 2012, 19:02 »
Hi guys
Its hard for me to explain my difficulty, but maybe somebody here knows this inside out.
Iv put vento headlights into my RHD golf, and the driver side seemed to plug straight in with a D shaped attatchmemt and they work fine on all settings.
The problem i have is the passenger side headlight has asmall lead attatched that has 4 cables that match up to blade conections on the rear of the light unit
The blades are in a vertical line and have diferent coloured wires visible that lead to a loom at one end, and at the end im dealing with iv got these 4 coloured wires and no way of knowing which one goes to which blade!
Mystified i am.
Anyone got the technical knowledge on this if i provide more detailed info?
H E E E L L P !!!!!!
Offline robjackson
Re: mk3 vento headlights into a golf
« Reply #1 on: 24 August 2012, 14:12 »
Anyone?
Offline robjackson
« Reply #2 on: 06 September 2012, 19:17 »
Still baffled!!!
Offline trog_nfs
« Reply #3 on: 06 September 2012, 21:11 »
Offline robjackson
« Reply #4 on: 16 September 2012, 11:57 »
Wow!
Actually got a helpfull response. Cheers fella.
Offline robjackson
« Reply #5 on: 18 September 2012, 07:37 »
I already have the plug shown here from eurowagons, but its the blade conections im having trouble with.
There in a certain order from top to bottom, and the cables to them must have to be in a certain order, so its a case of matchinf them up according to colours.
This is where im baffled
 :sad:
Offline trog_nfs
« Reply #6 on: 18 September 2012, 12:46 »
Use a multimeter or
Each colour on the eurowagens bit matches the inside of the headlight btw. E.g. Yellow cable runs to either the dipped or full beam.
Offline robjackson
« Reply #7 on: 18 September 2012, 21:30 »
I think i get that. So i'll have a good look in daylight tmorow. Hopefully i'll hav sussed it out then. Fingers crossed. Surely it cant be that difficult. Cheers my mate. Nice1
Offline robjackson
« Reply #8 on: 11 October 2012, 23:59 »
Traced all the colours to the correct fitting, from inside the light, into the loom, to the plug, into the cars loom,
Jobs a goodun, it worked, theyre all in the correct position,
So the lights are working as they should.
Thanks for te input fellas.
Well happy with the results.
