Author Topic: Current error codes and things already changed  (Read 1206 times)
Offline zorg86
« on: 19 August 2012, 15:35 »
STILL having problems with car - when warmed up starts to misfire
2001 AUM 1.8T - Remapped
Here is a list of parts changed
4 Coil Packs on recall
4 Spark Plugs
FULL Coil Wiring Harness
MAF Sensor
N249 Deleted
(and yes i have swapped coils packs and mis fire doesnt follow the coil pack when swapped around)
And here is the lists of codes i keep getting after deleting codes twice over -
17608 - Boost Pressure Control Valve
16684 - Misfire Detected
16687 - Cylinder 3 Misfire
16384 - ??????
16486 - Mass Air Flow Sensor Low Voltage
Anybody any ideas as i am struggling could it be a faulty MAF/MAF wiring i have disconnected the MAF (but not sure how long it has to be disconnected for to notice a difference)
HELP PLEASE  :cry:
Offline km
Re: Current error codes and things already changed
« Reply #1 on: 19 August 2012, 16:06 »
leave it disconnected maybe? then see if it still misfires?
Offline barrym381
« Reply #2 on: 19 August 2012, 16:16 »
you tried a new temp sensor on it  :smiley:
Offline zorg86
« Reply #3 on: 19 August 2012, 16:19 »
Left it disconnected for about 30 secs still was same thats why i said how long would need disconnect for?
Not tried new temp sensor wouldnt that mean that the fans wouldnt kick in though if that was faulty
Offline Nino
« Reply #4 on: 19 August 2012, 17:35 »
Fans will still work if temp sensor fails
Current - MK6 GTi Edition 35
Offline zorg86
« Reply #5 on: 20 August 2012, 14:00 »
Oh right anyone think this could be the cause or are they expensive and also where abouts are htey on the car?
An error code hasn't come up thogh?
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 20 August 2012, 19:03 »
check the injector loom, and swap the injectors around to see if the misfire moves with it. if its still misfiring on cylinder 3 then its time for a compression test. if compression comes back good put the engine to TDC and see if pistons 1 and 3 are sitting at the same height. a slightly bent rod can cause these symptoms :undecided:
