Author Topic: URGENT HELP NEEDED ON OVERHEATING  (Read 3676 times)
Offline pocket_gti
« on: 03 July 2005, 23:10 »
Hello its my first time posting on here and i Really need some help dubbersÂ… my MK1 1.8 Gti keeps overheating and I have no idea what it is   :huh:
So far I have changed the temperature sensor on engine head housing, the thermostat, the water pump, the radiator, the radiator temperature sensor, which is located at the bottom of the radiator and I have also tested my gauge on my dash using an vdo gauge which shows the fan coming on for a few seconds at 128 C and cuts out at 125 C and in the Bentley manual its says the fan should kick in at 97 C when the car is at stand still?
The electrics also seem ok because when I use a fuse to bridge the wires from the radiator temperature sensor the fan kicks in and stays on as it should with a fuse bridgedÂ…
Has anyone got any ideas because I have not got a clue any more  :cry: ??? Pleaseeeee help!
Thanks in advance
Mitz  :smiley:
Offline super427
Re: URGENT HELP NEEDED ON OVERHEATING
« Reply #1 on: 04 July 2005, 00:44 »
Hi,
Are there any symptoms of  head gasket leakage, loss of water, white smoke, dodgy oil?
Just prior to it starting to overheat had you had anything done to the car? replaced
water/antifreeze anything like that?
Also does it run hotter when you are driving normally or only becomes apparent when
at a standstill?
Regards,
Mark
Offline pocket_gti
« Reply #2 on: 04 July 2005, 19:45 »
Thanks for the quick response markÂ… there are no symptoms of head gasket leakage, or loss of water or white smoke and the oil isnÂ’t dodgy at all as its jus hand a recent oil change and the oil is very cleanÂ…
I have not done anything to the car before this problem started :huh:
It does run cooler when driving the car but it still seems like its over heating as the temperature gauge is ¾ of the way where as when its standing still the gauge is just short of the max water temperature level which doesn’t seem rite at all?? :sad:
Any other ideas would be much appreciated, as I really want to take the car to the GTI Festival at Santa pod this weekend :undecided:
Thanks again
Mitz :smiley:
Offline mk1
« Reply #3 on: 04 July 2005, 20:03 »
Is it overheating or is the guage reading high ?.
Steve.
Offline super427
« Reply #4 on: 04 July 2005, 21:04 »
Hi Mitz,
Seems like you've covered or replaced most of the cooling system, other thoughts are:
Is there an air lock in the system, possibly heater matrix, was the heater in the
full on position when refilled, does the heater work and drop the temps when full
on.
When you start from cold does the temp rise, then fall when the thermostat opens
and do the hoses and radiator gradually get hot. (watch you fingers).
Have you checked the plugs for any differences between cylinders also
is there any reason it would be running very lean, has the tickover increased at all
are the plugs white or the normal brownish grey?
Its a difficult one this if the guage is OK.Just thought is the system pressuring up as this
decreases the boiling point, check the expansion tank cap seal (carefully) or for any other pressure leaks.
Please please please be careful if you do any of this as super heated steam tends to smart abit
, I am not a mechanic and these are only
suggestions which might help, sounds like you know what your doing anyway.
let me know how you get on.
Regards,
Mark :smiley:
Offline pocket_gti
« Reply #5 on: 04 July 2005, 22:23 »
Thanks for all the suggestions,  :grin:
The heater was on full position when refilled with coolant; the temperature also does not drop when the heater is on? :huh:
The temperature also dose not drop when the thermostat opens. :huh:
The hoses do get very hot and I have also replaced the expansion tank cap, which didn’t help.  :undecided:
However I have not checked the plugs for any differences and also have no idea how to check if there is an air lock in the system? Any information on this would be greatÂ… will check the plugs tomorrow for any differences.
Here are also some pics of what the temperature shows in the car and also on a vdo gauge when the car had been running for 10 mins. (The fan still had not kicked in and when it did it only ran for 30 seconds then cut out again)  :huh:
The tick over seems to be fine as you can see in the picÂ…
Thanks for all the help so far, will keep you updated...
Mitz :smiley:
Offline super427
« Reply #6 on: 05 July 2005, 00:01 »
Hi,
Will have a think tonight and will talk to a mechanic friend tomorrow.
This is puzzling!! :undecided:
mark
Offline super427
« Reply #7 on: 06 July 2005, 00:24 »
Hi,
Just found a thread in the 'garage' section on 'overheating' from Dubslug sounds
exactly the symptoms you've been experiencing, not sure which sensor they're
on about but have a read, might sort you.
Regards,
Mark :smiley:
Offline pocket_gti
« Reply #8 on: 06 July 2005, 19:36 »
Cheers for that Mark, I checked the senor and that is exactly what it was  :grin:….
It was all because an aftermarket sensor was used which was reading the temperature too high :angry:Â…
Well chuffed its now sorted!!! :grin:
Thanks for all help
Mitz :smiley:
Offline super427
« Reply #9 on: 06 July 2005, 21:39 »
Fantastic, I love it when a plan comes together.
You shall go to the ball, well  Santa Pod anyway.
Regards,
Mark :smiley:
