Detailing
Chrome Exhaust
Topic: Chrome Exhaust (Read 7925 times)
MonkeyP
Guest
Chrome Exhaust
18 August 2012, 16:32 »
Has any one got any advice on how to clean the exhaust on the mk6!
Also can i use PB wheel sealant on it after i clean it?
Ginge 35Edition
Re: Chrome Exhaust
18 August 2012, 16:48 »
If they are really bad use autosol metal cleaner, then just keep on top of it even with a damp tissue between washes. Can't really give advice on sealing as I've always used my method with no trouble.
MonkeyP
Guest
Re: Chrome Exhaust
18 August 2012, 16:59 »
there not bad but finding some of the buildup is starting to stick quite hard to the tips so want to get rid of that first then prevent it from happening again.
Dan J
Pro Valeting and correcting paint since 95
Re: Chrome Exhaust
18 August 2012, 17:09 »
00grade wire wool and the Britemax metal twins will keep them looking good.
Jimble
Forum addict
Re: Chrome Exhaust
19 August 2012, 11:53 »
+1 for Autosol, you shouldn't need wire wool if they're not too bad, i put a little Jetseal 109 on mine now and again which helps to keep the buildup down so i only need to give them a wipe most weeks.
Ginge 35Edition
Re: Chrome Exhaust
19 August 2012, 22:00 »
As odd as it sounds I also clean in the pipes as far as I can too.
MonkeyP
Guest
Re: Chrome Exhaust
Reply #6 on:
19 August 2012, 22:57 »
http://www.amazon.co.uk/Autosol-0400-75ml-Metal-Polish/dp/B003XJ1ODM/ref=sr_1_1?rps=1&ie=UTF8&qid=1345413331&sr=8-1
Is that the right one? how often do i need to use it?
Jimble
Forum addict
Re: Chrome Exhaust
Reply #7 on:
20 August 2012, 17:39 »
Thats the stuff, i use it about once a month give or take cos of having the sealant on.
jamie1989
Re: Chrome Exhaust
Reply #8 on:
20 August 2012, 17:46 »
+1 on autosol works a treat on mine. Need sealant though as it goes the same after a few days lol
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Gambit
Forum addict
Re: Chrome Exhaust
Reply #9 on:
20 August 2012, 23:11 »
Brillo pad!
Detailing
Chrome Exhaust
