Author Topic: Gearbox oil change made things worse.  (Read 836 times)
Offline sierragls
« on: 18 August 2012, 10:26 »
Can anyone explain this. I changed the oil in my gearbox as occasionally it would pop out of reverse and whines a little when reversing, but now it pops out of reverse almost everytime now and it's a little stiffer to get into 1st when changing down. I know the eventual prognosis is a new gearbox, but most on here have seen improvements when they had done an oil change.
I used halfords 80/90 oil.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Gearbox oil change made things worse.
« Reply #1 on: 18 August 2012, 12:29 »
Use Castrol syntrans/syntrax fully synthetc it the gold bottle.   :smug:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Leroy
  • Golf GTI Anniversary 16v
« Reply #2 on: 18 August 2012, 12:58 »
I did the same when the synchromesh was going so it was crunching into 2nd gear, put new gearbox oil in and was worse so ended up getting a new gearbox.
