Author Topic: head unit keeps switching its self off!! doing my head in!!  (Read 4010 times)
Offline BobbyT
Re: head unit keeps switching its self off!! doing my head in!!
« Reply #10 on: 10 July 2005, 20:50 »
sorted it! had to run a new power from the battery and put in a new earth! works fine now and the sound is far far better! cheers all!  :grin:
Offline Mr Blue
« Reply #11 on: 10 July 2005, 23:07 »
you still have to do the halfords scam for me. comon! :grin:
Offline Organisys
  • Old and Slow...
« Reply #12 on: 11 July 2005, 13:03 »
Please make sure that you have a fuse somewhere in your new live feed. You can buy an inline fuse holder.
Offline BobbyT
« Reply #13 on: 11 July 2005, 16:45 »
cheers for that but i have put one near the battery already!  :smiley:
Offline silkyballs
  • more tea vicker??
« Reply #14 on: 15 August 2005, 17:39 »
if i was you i would take it into a shop and have it looked at befor you blow it up all together dude!
http://[img]
Offline ian007miles
« Reply #15 on: 10 June 2007, 20:18 »
im having the same trouble same car same head unit wot wites did u change and wre did u erth if thanx ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline Heyho
« Reply #16 on: 10 June 2007, 20:28 »
You can beef up the power wire all you want, but if the earth is not sufficient, you'll still have the same fault.
Check your earth connection, or better still, run a direct earth straight to chassis.  Obviously the main feed could be the cause, but people often overlook the earth - it's just as important.
Offline tommk3cab
« Reply #17 on: 11 June 2007, 19:42 »
indeed heyho, the earth is essentialy a drainhole, if its blocked ( even slightly will matter) or cut off hows the power getting round the rest of the circuit?! very important!
