Author Topic: eaton charger mount for an abf, who makes them?  (Read 2138 times)
Offline mk2addict
« on: 17 August 2012, 18:16 »
Does anyone know where I can get a bracket made up to fit an eaton supercharger to my abf, it'll be a charger off of a mini cooper s
Offline danny_p
Re: eaton charger mount for an abf, who makes them?
« Reply #1 on: 17 August 2012, 23:42 »
hopefully you cant get an of the shelf mount for the eaton m45.
somewhere may have drawings or even a few brackets for M90 / M62  iirc brackets were quite simpel to make   shove the scharger were the alt was and alt where the ac pump was
all the VW's have gone bar 1.
Offline tshirt2k
  • Been there...Done that...
« Reply #2 on: 18 August 2012, 05:17 »
A guy makes them n7ndo on edition38 or eatonmk2 on cgti. Goes where AC compressor usually goes. M45 is a bit small for an ABF though. Ideally you would want an m62 but they're hard to come by.
Mk3 ABF 16VT Megasquirt V3
Offline mk2addict
« Reply #3 on: 18 August 2012, 07:20 »
Had thought about the m62 but like u say hard to come by, but ill have a read up and see which would be best to use I've a few build threads and most seem to use the m45. Bigger is better tho so will have a look .
« Reply #4 on: 18 August 2012, 10:11 »
I doubt an E45 will be man enough, it is designed for up to a 1.6
Offline mk2addict
« Reply #5 on: 18 August 2012, 15:58 »
Read up a bit more and m45w are good to add 60hp and I want a few more will go m62
Offline tshirt2k
« Reply #6 on: 18 August 2012, 17:03 »
Read up a bit more and m45w are good to add 60hp (and lots of heat )and I want a few more will go m62
