Author Topic: will not rev over 5k  (Read 1187 times)
Offline robiwill
« on: 17 August 2012, 16:45 »
Right pulling my hair out here
car 1999 Mk3.5 cabriolet with 1.6aft engine
replaced, all plugs all leads coil pack, distributor, all wiring checked, timming checked all ok
fault code is sporadic signal on camshaft sensor. can clear this code but as soon as car hits 5k rev limiter kicks in and code reappears
doing my nut in any ideas or cures
Offline dan2252
Re: will not rev over 5k
« Reply #1 on: 17 August 2012, 16:55 »
cam sensor?
MK4 golf 1.8 turbo agu :)
Offline robiwill
« Reply #2 on: 17 August 2012, 20:46 »
camshaft sensor is part of the distributor hence changed
Offline dan2252
« Reply #3 on: 17 August 2012, 23:24 »
i see.. dont know anything about these engines.. you say checked timming is that cam timming or ignition timming? my last car cam timming was out that brought up cam sensor faults
Offline robiwill
« Reply #4 on: 18 August 2012, 14:30 »
yes and checked against flywheel too so 100% correct, pleased help someone been told most likely ecu, hoping its not so open to ideas
Offline dan2252
« Reply #5 on: 18 August 2012, 17:33 »
does sound like a electrical, ecu problem of some kind i cant see how else it could cut the limiter in :/ hmmmm its a head sratcher that one
Offline Chris.
« Reply #6 on: 18 August 2012, 17:36 »
is the car stood still when you try it?
Click For Build Thread
Offline robiwill
« Reply #7 on: 19 August 2012, 00:02 »
yes but does the same thing when you drive it hit 5k and rev limiter kicks in. if its ecu its good old ebay and ecu chiped key and transponder but trying to see it anything else first as will be mighty pi@@ed if change all that and same issue, thanks for the help so far and ideas though
