Author Topic: Just as misfire kicks in i get these codes  (Read 1260 times)
Offline zorg86
« on: 17 August 2012, 12:00 »
HI guys
Could this code 17608 - N249 valve be the cause of my misfires?
I dont want to bypass it as i do not have the experience to be honest. But When the car starts to mis fire it brings up this code then 10 mins later hte multiple mis fire codes etc.
Please help as i have changed - Plugs, Coil packs, Coil wiring harness, MAF
Offline Dalo Harkin
Re: Just as misfire kicks in i get these codes
« Reply #1 on: 17 August 2012, 12:03 »
N429 delete is easy there is a really good guide on Vortex
http://forums.vwvortex.com/showthread.php?4893472-DIY-Ultimate-SAI-N249-PCV-EVAP-Delete
« Last Edit: 17 August 2012, 12:05 by Dalo Harkin »
Offline zorg86
« Reply #2 on: 17 August 2012, 12:04 »
Yes but would this be the problem wouldn't buying a new one just fix the issue
Offline Dalo Harkin
« Reply #3 on: 17 August 2012, 12:17 »
Its more than likely one of the vac lines rather than the N249 itself, you could always replace the vac lines, but when people on here have tried the nipples on the N249 snap off, so in my opinion you are better off ripping it out and replacing with silicone hose
Offline zorg86
« Reply #4 on: 17 August 2012, 12:38 »
come and do mine for me then  :grin:
Offline Dalo Harkin
« Reply #5 on: 17 August 2012, 12:56 »
where abouts are you?
Offline zorg86
« Reply #6 on: 17 August 2012, 13:16 »
warrington
