Author Topic: RNS510 Firmware Update 3810 / 4020  (Read 39321 times)
Offline p3asa
Re: RNS510 Firmware Update 3810 / 4020
« Reply #50 on: 19 August 2012, 22:09 »
Excellent, you'll notice a massive difference   :smiley:
That's a few times you've mentioned this  :undecided:  What are the differences?
Offline Rislar
« Reply #51 on: 19 August 2012, 22:17 »
Well seeing as ive no details on your car, ill assume its the older version!
This is the difference:
NEW Faster navigation and user interface
NEW Automatic illumination control
NEW Enhanced destination input
NEW hold down the setup button for 30 seconds and get the following menus: FM, AM and the new VERSION INFO (map version and type, hw and sw versions)
NEW Compass
NEW POI- see Volkswagen RNS 510 Maps POI – New Features with firmware 3xxx
NEW Languages – Arabic,  Russian, Turkish and Polish
Speed Limit Display
Stability Improvements
Faster Startup (this has been improved on 2720)
Display OPS and RVC at the same time
SDHC 32 GB Support (HW04 and above)
Display Off on extras tab
Climatronic control if approriate climatronic fitted
Clock display if RNS 510 swtiched off
Excluded roads (under route options)
GPS coordinates entry
Additional adjustments for video
Larger RVC screen with transparent menus at the side
Offline p3asa
« Reply #52 on: 19 August 2012, 22:24 »
Mine is the revision "C"
Cheers.
Yeah I read that in mygti site but what does it offer in real money terms   :grin:
Especially all the "NEW" sections.
MonkeyP
« Reply #53 on: 19 August 2012, 22:47 »
Ok mine works now.
started of with a revision C unit and 2720 firmware
upgraded to 3810 using the following link
http://www.my-gti.com/3093/volkswagen-rns-510-firmware-upgrade-to-version-3810-3814-3816-3818
took about 45 minutes
now i am currently updating to 4020 so will update once its finished and i have reinstalled the maps!
I want to say thank you to Rislar
But ScottA was the biggest help taking time out of his day to help me check everything and he even stayed to help me burn all the software for me and made sure that it worked. so thank you mate as i said owe you a few drinks!
Will put up some pics i have finished everything.
Offline Rislar
« Reply #54 on: 19 August 2012, 22:52 »
Excellent and good man, glad its sorted  :smiley:
MonkeyP
« Reply #55 on: 20 August 2012, 00:01 »
Ok i have done everything! only one problem i have lost all my POI's which is a bit strange!
Any help on this one?  :angry:
Offline ScottA
« Reply #56 on: 20 August 2012, 00:08 »
I say get the V8 map on there and try again. I'll PM you in a sec
MonkeyP
« Reply #57 on: 20 August 2012, 00:12 »
Ha ha ha. Comin to the rescue again.
Hope it ain't anything to do with the partition on the HD. Tried putting adding the cameras from one of the posts on here but even that didn't work. Been a long day!
Offline Rislar
« Reply #58 on: 20 August 2012, 00:27 »
Thats something ive not tried as im waiting for the V8, ive been messing with VIM this evening  :smiley:
MonkeyP
« Reply #59 on: 20 August 2012, 14:52 »
If u find a link let me know! I hav found a few but not sure if they will work and also I think I am limited as I have a mac and that was the reason I wasnt able to the software to work last time!
