Author Topic: RNS510 Firmware Update 3810 / 4020  (Read 39233 times)
MonkeyP
Re: RNS510 Firmware Update 3810 / 4020
« Reply #30 on: 19 August 2012, 15:47 »
Ok my files are .nrg files. do i need to do something with the file before i put it on the disc?
Offline Rislar
« Reply #31 on: 19 August 2012, 15:50 »
Yes they should be ISO files, very odd yours are NRG's though  :shocked:
MonkeyP
« Reply #32 on: 19 August 2012, 15:53 »
ye they are .nrg when i extracted them. hmmm. what did u use to extract them cos they always come up as nrg
Offline Rislar
« Reply #33 on: 19 August 2012, 15:55 »
Winrar fella!
MonkeyP
« Reply #34 on: 19 August 2012, 16:05 »
Yep not working. on the site its says
Download the files and extract them using winrar and you will have a NRG format ISO file to burn. Using Nero burn a DVD+RW or DVD-R (CDR works as well) at a slow speed (4 x is ok for DVD and 16 x for CD).
So it should work i would of thought.
tried it with a dvd+r as well and same thing.
Offline Rislar
« Reply #35 on: 19 August 2012, 16:11 »
Are you doing the 381X ?
Offline Rislar
« Reply #36 on: 19 August 2012, 16:16 »
Looking back i used this as the other was in different parts hence the .nrg files.
Try here for mine:
http://www.mk5golfgti.co.uk/forum/index.php/topic,23779.0.html
Its deffo an ISO file, i thought you where doing the 4020 fella!
MonkeyP
« Reply #37 on: 19 August 2012, 16:19 »
Ye I decided to copy ur process.
Might have to find someone with windows as only have macs here.
Offline Rislar
« Reply #38 on: 19 August 2012, 16:22 »
Right ive found the problem, you need to use this site for it:
Ive just done it with the mac and its an ISO File  :smiley:
Hopefully that will sort you, just been through the whole process and updated the original post !!
Offline Belix
« Reply #39 on: 19 August 2012, 16:34 »
The 3810 files I downloaded of the my-gti also came out in nero (NRG) format, but I just downloaded ImgBurn and it created the disk direct from that.
