Author Topic: Grinding/knocking when accelerating  (Read 2532 times)
Offline scottishpedro
« on: 16 August 2012, 21:11 »
Hi all
I have an 1990 8v GTI
Over the past few weeks I have noticed a bit of a knocking sound when I floor it/come on and off the throttle and sometimes when driving over bumps and potholes.  It is coming from near the passenger footwell and I initially thought it might be engine mounts going and causing the exhaust to knock however they were renewed only a few thousand miles ago.  I also wondered if it could be the gearbox mounts?  Tonight I floored it in 2nd and 3rd and in the high rev range there was a lot of knocking/grinding, not very loud but noticeable.
Any suggestions?
Thanks in advance
Pedro
Offline Mr Blue
Re: Grinding/knocking when accelerating
« Reply #1 on: 17 August 2012, 01:15 »
Handbrake on, 1st gear, clutch up and does it knock?
« Reply #2 on: 17 August 2012, 08:54 »
Hi mate
Tried this, brought the clutch to biting point and no knock.... It seems to happen more often when the car is accelerating and going over potholes etc.
Offline Gambit
« Reply #3 on: 17 August 2012, 11:35 »
check your droplinks & top mounts
« Reply #4 on: 17 August 2012, 13:37 »
Will do cheers
Offline JamesS
« Reply #5 on: 17 August 2012, 16:43 »
Likely to be worn lower ball joint or wishbone bushes, they knock when you coast over bumps or under soft accelerating/braking. Tie rods are more of a popping sound with vague steering. Top mounts creak as well as knock.
Hope you get it sorted!
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
« Reply #6 on: 17 August 2012, 17:24 »
It seems only to happen when the car is accelerating, ie not when coasting and going over bumps/pot holes.  If I floor the accelerator on a bumpy surface it gets significantly worse which makes me think engine/gearbox mounts?
Thanks
Offline weazgti
« Reply #7 on: 17 August 2012, 20:04 »
What downpipe/manifold?
Is this the same noise you posted about a while ago?
« Reply #8 on: 25 August 2012, 01:48 »
Just standard down pipe and manifold. Got exhaust hangers replaced and seems to be better.  The original sound I posted about is still present but very quiet, I had it looked over and there is nothing obvious just now.
