Author Topic: Clutch kit for 1.8t  (Read 911 times)
Offline balderz
Offline jamie1989
Re: Clutch kit for 1.8t
« Reply #1 on: 16 August 2012, 09:45 »
Have you tried re-aligning the gear linkages?
I wouldnt say you need a new clutch if its differcult to engage a gear, it could be a faulty slave cylinder or a simple re-aligning issue.
Take a look before as you be spending more than you have too.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline balderz
« Reply #2 on: 16 August 2012, 10:00 »
Cheers I'm going to check that as well I always look at worse case then know roughly how much it's going to cost
